at first I was like
![Name: KgOds.gif
Size: 1.58 MB](https://g35driver.com/forums/attachments/picture-share/269100d1683124871-aggressive-wheels-stretched-tires-post-em-up-some-nsfw-kgods.gif)
then I saw last pic and I was like
![](https://profile.ak.fbcdn.net/hprofile-ak-ash2/41787_214277156210_9019_n.jpg)
what is this going straight into or out of ANY driveway?son...
Hey guys, I'm looking at getting new wheels but not sure about one thing. Is it possible to fit a
19x10 -16 Up front w/out a pull? Also would 225/35/19 tires be too small to run on the 10? The rears I'm pretty sure will fit fine they are 19x11.5 -10 my only worry is ifi can use my old tires since they are brand new. It would be 245/35/19 on the 11.5. If anyone has this set-up that could chime in I'd greatly appreciate it
![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
I had 19x10 -10 up front with 225/35 and was fine . 6mm more was doable . Just pinch your front fenders flat Vic.
For the rears, your gonna need a pull. I'm at 11.5 -14, and had to get them pulled and already runnin -4.8 camber .
The 245 /35 on the 11.5 will be fine depending if it runs large or not
Ehh a lot of people say they run true, but from my experience they run sorta large . Or maybe it's the square sidewall.
And yea I get you, 225/35 on the 10 would be perfect . 245/35 v12 would be good on the 11.5 too, only problem I see is the tire is too hard and won't allow It to stretch right and hold air
