#3454
#3456
#3457
Quick question for the offset gods about my s2k since noone on s2ki can help me. Im currently running 17x9" +45 with a kaumo escata205 that streches nicely with -1 camber with tons of clearance and a 17x9.5" +38 rear with a 245 bfgoodrich kdw ta that has a super meaty stretch. Im looking to swap my rear 9.5" +38 to the front with the kaumo 205 tire and get a 17x10" +18 with a general 235 tire that should stretch like my front and not like the bfgoodrich with a meaty stretch. Ive calculated that the -20 difference in the offest is about .78XXX inches wider. Will a 10" +18 rear with a thin wall streched 235 tire with -4 through -5 camber fit on my car if im currently running a 9.5" +38 with a meaty stretch 245 with -3 camber?? PLEASE HELP ME
#3459
#3460
Current specs are:
F: 9" +45 on a 205 with -1 camber
R 9,5" +38 with a meaty 245 with -3 camber
New set up
F: 9.5" +38 with the thin wall 205 hopefully keeping the -1 camber. Offset calculator says it will be 13mm wider on the outer position.
R: 10" +18 with a 235 possibly a 225 general with hopefully -3.5 or -4 camber. Offset calculator say it outer position will be 26mm wider(25mm = 1 inch) so ill have to add a degree or so of camber
How does that sound?
Thanks for the offset calculator gtrefever, very helpful!
Pic for reference
Look at all the front wheel clearance
New set up
Pic for reference
![Name: ashcam349.jpg
Size: 121.7 KB](https://g35driver.com/forums/attachments/picture-share/230930d1501885145-aggressive-wheels-stretched-tires-post-em-up-some-nsfw-ashcam349.jpg)
#3461
#3463
Going to look sick. My front rim is completely flush with the fender if you look from a top view as well as the rear rim but i want poke like shane has but with light azz mono forged rims instead of the common 3 pc rim. With the new set up my rear rim will poke .7 inches past the fender and the front rim will poke .5 inches with my current alignment specs so it will poke but not look mexi poke. Im excited as hell to order these new rears tomorrow
Im putting off buying these headlights to buy the rims and my girl thinks im crazy to upgrade my rims .5"s all around. she doesnt understand its about changing offsets as well. she thinks i should get these audi style headlights instead of the rims. http://www.s2ki.com/forums/index.php...#entry16914436
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
#3464
