Question, (not entirely about stretched setup or anything, but no one has been able to answer my question and I need feedback ASAP), I have a set of wheels 19 x 8.5 and 9.5 with 255/40/19 in the rear, what would be the best size tire to put in the front in order to match this?
that would be a perfect match
Why so much camber
Small ***** syndrome??? You honestly think you need that much camber to make those wheels fit with those specs? Pssshhhh...noob
w4kj4k, wheels look good and I like the set up. Are you running that much camber because you opted for a wider tire setup vs. the common 225/245 setup on a 10/11 wheel combo? Thanks ahead of time for the response.
And the reason I ask because one of my boys was running a 20x11 -5 setup with a 255/30 and he was only at max -4 degrees camber and my brother is at max -3.8 degrees camber on his 19x11 -21 setup with a 245/35 tire.
Granted they have 350z's but are fenders have a tad bit more room then theirs.
