Old May 5, 2014 | 09:29 PM
  #40531
Urbanengineer's Avatar
But the reality. Will if blow and damage your $1K wheel?
Yes.
Old May 5, 2014 | 09:36 PM
  #40532
Lartytiejdke3's Avatar
In Oklahoma we *** potholes..
Old May 5, 2014 | 11:01 PM
  #40533
The Stimulation's Avatar
Yes.
Actually, no... I once had low tire pressure, my fault for not checking up on it but it was probably around 20 something PSI, that's a 235/35 on an 11. Lip of the wheel got bent a little, less than $100 to fix. Mind you I was driving on the freeway, there was no shoulder but I drove approx a quarter to half mile to a safe spot. Lane markers were impossible to avoid, it's a hit or miss and I hit (as if wheel on pavement isn't bad enough).
Moral of the story: Your wheels are as safe as you are. Check pressure on a frequent basis and you'll be good. I've driven with a full load and tires rubbing constantly on the rear fender and didn't have any problems other than the obvious, tire wear.
That said, I disagree.
Old May 5, 2014 | 11:11 PM
  #40534
Originally Posted by The Stimulation
Actually, no... I once had low tire pressure, my fault for not checking up on it but it was probably around 20 something PSI, that's a 235/35 on an 11. Lip of the wheel got bent a little, less than $100 to fix. Mind you I was driving on the freeway, there was no shoulder but I drove approx a quarter to half mile to a safe spot. Lane markers were impossible to avoid, it's a hit or miss and I hit (as if wheel on pavement isn't bad enough). Moral of the story: Your wheels are as safe as you are. Check pressure on a frequent basis and you'll be good. I've driven with a full load and tires rubbing constantly on the rear fender and didn't have any problems other than the obvious, tire wear. That said, I disagree.
Well thought out. Thank you.
Old May 5, 2014 | 11:29 PM
  #40535
No prob. No two situations are alike, but quality of the wheel will make a difference. Perhaps I just had good luck, but with temperature changes always a good idea to look at your tire pressure. I was running I think about 40 PSI? Low to mid 20's isn't good for a regular tire, but when stretched, definitely a danger.
I've always considered a 225/35 on a 9.5 and 245/35 on a 10.5 to be a "safe" and common stretch. Once you start going with a smaller tire on those widths then it's as if you're beginning to test the waters. Wheel quality has a lot to do with it too. I had work Wheels. As opposed to some cheap Moz wheels I had back in the day with 245/40 on an 8.5, little potholes damaged the wheels sadly.
Old May 6, 2014 | 01:00 AM
  #40536
guitarrocker98's Avatar
Originally Posted by Shane-O-Mac
I have a 225 on a 10.5. Come at me.
Old May 6, 2014 | 04:19 PM
  #40537
Shanes_G's Avatar
Can you hit pot holes?
some times i hit more than potholes.
Old May 6, 2014 | 06:10 PM
  #40538
andy_cliff's Avatar
Some Miata love for those who are willing to accept it
and this one because it is tough as hell...well as tough as a miata can be
And these
Old May 7, 2014 | 02:58 AM
  #40539
saywat?'s Avatar
Wow that frz looks sick. I'm surprised the owner didn't go for the blk front lip look
Old May 7, 2014 | 03:47 PM
  #40540
that trunk...
Old May 7, 2014 | 04:48 PM
  #40541
PLENUMCOUPE's Avatar
I hate every car in that post 0_o
Old May 7, 2014 | 05:17 PM
  #40542
GR6RR's Avatar
^ I just want to know, only if you want to share....
What do you not like about each one of those cars? Just curious, that's all...
Old May 7, 2014 | 05:27 PM
  #40543
Miatas just not my cup of tea. I can't stand anything slammed with tons of camber and stretched tires. I'll never understand why people find that look attractive. As for the scion the spoiler is just way too much and I think Meisters are the ugliest rims also
Old May 7, 2014 | 05:52 PM
  #40544
Shanes_G's Avatar
why are you in this thread?
Old May 7, 2014 | 06:01 PM
  #40545
Shanes_G's Avatar
here is my stretched pos.
