Old Oct 31, 2009 | 02:00 AM
  #5671
Royal_T's Avatar
If I ever build a S13 that is def the kit I am going to get...
Old Oct 31, 2009 | 03:08 AM
  #5672
GR8NISS's Avatar
Old Oct 31, 2009 | 03:16 AM
  #5673
soysauce21's Avatar
anymore pictures of the nsk or s2k?
Old Oct 31, 2009 | 04:21 AM
  #5674
Lunek's Avatar
Originally Posted by ShanesG
Wheel fitment and lip size are 2 completely different things.
Fitment wise a 5" lip will look just as good as a 5.5" lip with the same offsets/tire size. Noone will know the difference unless you were to physically go and measure.
I am able to fit a 5.5" lip with my bbk which is still bigger than almost everyone w/o a BBK. So you can easily have the best of both worlds. Having a bbk doesn't make a set up less aggressive. It makes you unable to run a slightly bigger lip, that is all.
In your opinion having a .5" bigger lip is more jaw dropping than having a ballin a$$ BBK shining through.
And IMO i think not having a bbk takes away from the JAW DROPPINGNESS of a setup!
opinions are great since everyone gets one of their own
dude haha thats where you and i are different, jaw dropping to you is 5.5 inch with bbk, nonthing against bbk but just not for me, im at 6in out back and can running bbk if wanted too but the aggressiveness of over 178mm lip pokin thats where its at, thats jaw dropping to me but opinion is just like @sshole everybody have one haha like it or leave. We can debate all day bout bbk this n that but i aint, i love all cars aggressive bbk or not as long as you stance right, with that said UNITED WE STANCE HAHA SECREST OUT!!!!! haha
Old Oct 31, 2009 | 09:42 AM
  #5675
Frankieg35's Avatar
I understand where Shane is coming from but I like to jave the biggest lips possible.. Just make sure you paint your calipers black and keep them clean..
Old Oct 31, 2009 | 11:17 AM
  #5676
D&G35's Avatar
Wow! i luv the nsx and the two 240's...nsx is clean as hell...and the 240's are just sick...talkabout slammed..Moarrrr!
Old Oct 31, 2009 | 11:31 AM
  #5677
robzone's Avatar
then why didnt you stick with your 5" lip out back...I know you had them replaced because they cracked, but y not stick with the same size if .5" doesnt make that much of a difference. I liked the 11.5 set up better then the 12 ....JMHO..my set up coming in has 5.5 in rear with brembos neg offset ....does that count ...I also think if your gonna run stretched...at least run something with enough side wall to semi protect the wheel...I think you should have at least 265/35 JMHO...still like your G Shane
Old Oct 31, 2009 | 03:28 PM
  #5678
ShanesG's Avatar
I went with .5 bigger cause I can easily fit it since I was only at -2.5 camber that's why. I'll be dong the same thing wth the fronts as well. But it's true you me nor anyone else can really tell the difference in .5". as for tire i was using the 265 already so I didn't change it I will always stick with 30 series cause again, IMO less tire looks better. I donno why this turned into a pissing contest lol so let's just end it there
  #5679
eurodre's Avatar
Old Oct 31, 2009 | 03:37 PM
  #5680
ShanesG's Avatar
Damn that's so clean!
Old Oct 31, 2009 | 03:41 PM
  #5681
fatboy.yoshi's Avatar
a self proclaimed offset god
Old Oct 31, 2009 | 04:31 PM
  #5682
ShanesG's Avatar
^How so??? I never even stated i was. I've done ALOT of research and have taken the time to learn everything possible about it. But i have never proclaimed that.
Old Oct 31, 2009 | 04:38 PM
  #5683
eurodre's Avatar
btw levon i see that you found the place at the santa anita mall! you should see the lighting at night! gorgeous!
Old Oct 31, 2009 | 04:39 PM
  #5684
Inyong1988's Avatar
http://www.s2ki.com/forums/index.php?showtopic=740798
Old Oct 31, 2009 | 05:30 PM
  #5685
The Stimulation's Avatar
Yeah, I definitely gotta check it out then. I stiffened up the preload a lil, but also raised it a lil more. It matches more with the front, but I think I need it a quarter inch lower. Looks pretty good, buy I don't really get any more wheel mating with the fender anymore.
