Old Feb 11, 2009 | 01:38 PM
  #1171
ShanesG's Avatar
Nope, got another 1/4-1/2 for the rear, and i can put the front on the ground!!!
Old Feb 11, 2009 | 02:51 PM
  #1172
dorkidori_S13's Avatar
and that is why you spend the money on GOOD coilovers right there
Old Feb 11, 2009 | 02:53 PM
  #1173
Originally Posted by gtrefever
yeah, i might need you to check out my rear coilovers. the rear right side makes a loud thumping noise everytime i go over an un even part in the road is that normal?
after you put the coilovers on your car...did you tighten up the spring perches and fix the spring droop so you actually have proper spring preload again? (you have to do this with ALL coilovers that utilize perched lockers)
oh wait...are your coils actually spring on damper or seperate spring & damper ?(i know certain companies make spring on damper setups for the FM chassis and some dont)
Old Feb 11, 2009 | 02:56 PM
  #1174
gtrefever's Avatar
yeah the spring and damper are seperate.
Old Feb 11, 2009 | 03:00 PM
  #1175
could be a few things
1)somethings loose
2)spring has finally settled and your perches need to be tightend up a bit
3)your damper is blown (which is the least likely of the 3)
it sounds like your preload is a bit off...check the tension on your spring perches
Old Feb 11, 2009 | 03:06 PM
  #1176
ShanesG's Avatar
The F&F coils retail for ~1300, but i seen a vendor on here selling them for $1125 i believe...very good deal, and it rides suprisingly smooth!!
Old Feb 11, 2009 | 03:39 PM
  #1177
gtrefever's Avatar
it might be that the spindels or perches are loose i know my dampeners arent blown cause i dont max them out. ill check to see if there loose.
Old Feb 16, 2009 | 05:09 AM
  #1178
Thinkdiesel's Avatar
this one is so crazy i had to post it, literally reversed the barrel to the normal lip
Old Feb 16, 2009 | 10:29 AM
  #1179
driftsucky's Avatar
Originally Posted by Thinkdiesel
The guy in the blue hat sez"YO SON!! THAT IZ SO DTM TYTE!!! YO!!! LOOK AT DAT MAD CAMBER VEE DUB STIZYLE SON!!! WOOOOOOOOOWW
lolz
Old Feb 16, 2009 | 11:00 AM
  #1180
GreenGoblin's Avatar
The goblin resurrection
Wow that is nutzo
Old Feb 19, 2009 | 04:12 PM
  #1181
ShanesG's Avatar
had to post this my god i would trade my G
Old Feb 19, 2009 | 04:15 PM
  #1182
G U LATER's Avatar
^one of the sexiest S2k's I have ever seen.
Old Feb 19, 2009 | 04:19 PM
  #1183
djkace77's Avatar
The last pic is money.....Beautiful...
Old Feb 19, 2009 | 04:22 PM
  #1184
CandlestickPark's Avatar
ill Sedan
That S2K is Supa Sexy!
Old Feb 19, 2009 | 04:28 PM
  #1185
gtrefever's Avatar
heres another one of that s2k and other s2k.
