SxExCx's Polished Plenum Installed
Old Aug 25, 2008 | 01:24 PM
  #31
Boston's Avatar
Thanks Ernest, DM2 coolant kit is next. Glad to see you and Mike got your done over the weekend.
Old Aug 25, 2008 | 01:28 PM
  #32
Chamoru671's Avatar
Yea that was an awesome install til midnight.
Old Aug 25, 2008 | 01:31 PM
  #33
Boston's Avatar
Originally Posted by SxExCx
It would actually be $235 INSTALLED since he is local
Even better!
Old Aug 25, 2008 | 03:10 PM
  #34
Boston's Avatar
I've gotten quite a few questions about the plenum bolts I used. I got them from a local hardware store and they are called "M6 socket cap bolts". I used the same length bolts as listed in the Motordyne install guide which for me was (11) 35MM, (3) 55MM and (4) 70MM. I have a 5/16 plenum spacer so the bolt lengths will vary depending on the size of spacer. If you're completely OEM, the bolt lengths should be listed in the service manual.
The JDM fender washers that I used are compatible with the M6 socket cap bolts. Hope this helps.
Old Aug 25, 2008 | 03:24 PM
  #35
SxExCx's Avatar
yup, I did the same thing
Old Aug 25, 2008 | 07:06 PM
  #36
w0ady's Avatar
fgc moderator
looking good bro.
Old Aug 25, 2008 | 07:19 PM
  #37
G U LATER's Avatar
is there any other part of the engine where you can do that also?
Old Aug 25, 2008 | 07:25 PM
  #38
Boston's Avatar
^Change out the bolts?
Old Aug 25, 2008 | 07:27 PM
  #39
G U LATER's Avatar
yea and to put the
colored washers
Old Aug 25, 2008 | 07:38 PM
  #40
Boston's Avatar
Sure. I used PasswordJDM fender washers for other parts of the engine bay and the ones from Ebay on my plenum. Anything tht uses an M6 bolt you can use with the fender washers. The ones that come with the washers are 15 or 20mm bolts
Old Aug 25, 2008 | 07:56 PM
  #41
G U LATER's Avatar
why didn't you use the ebay one all over?
Old Aug 25, 2008 | 07:58 PM
  #42
SxExCx's Avatar
Lovin' the new avatar Bruce!
Old Aug 25, 2008 | 08:00 PM
  #43
Boston's Avatar
Thought you'd like that!
Old Aug 25, 2008 | 08:03 PM
  #44
Boston's Avatar
It was just preference. The PasswordJDM ones were flat aluminum unlike the conical ones I used on the plenum.
  #45
SxExCx's Avatar
all it needs is a price tag and my email address...lol
