SxExCx's Polished Plenum Installed
Old Aug 26, 2008 | 10:45 AM
  #61
Boston's Avatar
^yeah, what Danny said.
Old Aug 26, 2008 | 04:59 PM
  #62
Rhino_111's Avatar
There is nothing wrong with attention to detail especially if you are going to be popping the hood for people. I say money well spent. Your bay looks excellent and very close to what I am going to end up with except in blue. Props to SxExCx for a great product as always. I will be ordering mine down the road from you.
Oh and Boston, when you get your other intake tube hit me up about your polished Z-tube! I will take it off your hands!
Old Aug 26, 2008 | 05:03 PM
  #63
Boston's Avatar
^I'll keep you in mind when that happens. The polished/blue will look very good on BS. Thanks
Old Oct 25, 2008 | 09:03 PM
  #64
taylordio's Avatar
Originally Posted by Boston
I've gotten quite a few questions about the plenum bolts I used. I got them from a local hardware store and they are called "M6 socket cap bolts". I used the same length bolts as listed in the Motordyne install guide which for me was (11) 35MM, (3) 55MM and (4) 70MM. I have a 5/16 plenum spacer so the bolt lengths will vary depending on the size of spacer. If you're completely OEM, the bolt lengths should be listed in the service manual.
The JDM fender washers that I used are compatible with the M6 socket cap bolts. Hope this helps.
So did you only get one set of fender washers for the plenum bolts?
Old Oct 25, 2008 | 09:36 PM
  #65
bigc's Avatar
Wings Nation
You only need one set of the JDM / Ebay washers if you're just doing the 6 bolts in the center of plenum. You also only need three (3) 55MM and three (3) 70MM M6 socket cap bolts if you're just doing those 6 bolts in the plenum.
Old Oct 25, 2008 | 09:47 PM
  #66
taylordio's Avatar
so which ones are the 35mm? are those the smaller bolts around the outside of the plenum? and which one is the fourth 70mm that Boston was saying he bought?
Old Oct 25, 2008 | 09:55 PM
  #67
bigc's Avatar
Wings Nation
the 35mm bolts are on the perimeter of the plenum, and the 4th 70mm bolt is towards the rear next to the throttle body.
Old Oct 25, 2008 | 10:29 PM
  #68
taylordio's Avatar
yeah thats what i thought. ok thanks for the help
Old Oct 25, 2008 | 10:31 PM
  #69
bigc's Avatar
Wings Nation
NP, thanks to SxExCx & Boston for helping all of us!
Old Oct 25, 2008 | 10:43 PM
  #70
tragedycat's Avatar
Where did you get that engine cover without the Nissan badge and 3.5L lettering? Also did you DIY paint it or is it professional?
Engine bay looks good btw.
Old Oct 25, 2008 | 11:12 PM
  #71
Boston's Avatar
engine cover is a generic CF from ebay that I had professionally done locally.
Thanks
Old Oct 25, 2008 | 11:15 PM
  #72
Boston's Avatar
Thanks, that's what the forum is all about!
Old Oct 25, 2008 | 11:32 PM
  #73
Sponger's Avatar
6MT Brembo Coupe
I like.
Old Oct 25, 2008 | 11:39 PM
  #74
Boston's Avatar
I need to get the rest of the Pi-Thon fittings on. As soon as we do the coolant bypass pipes, I'll put them on.
Old Oct 25, 2008 | 11:41 PM
  #75
taylordio's Avatar
haha i actually just ordered my own polished plenum from sxexcx today! i saw his fender washers on his and love them. but i am in the process of dressing up my engine bay. next step is a strut bar...
