jlin615 Photoshoot! SaadPhotography *56k = Fail*
#31
G
*Just to clarify*
This sick looking IP G coupe belongs to the member jlin615.
I did a photoshoot for jlin615, and my photos are located here:
https://g35driver.com/forums/picture...56k-death.html
The photos in this thread were taken by my friend, Matt Saad.
#32
*Just to clarify*
#34
I'm thinking about using 245/30/20 for my next front. Right now the space between my fender and tire is pretty even all around, and sidewall height look about the same front and rear. Will I have more fender gap in the front if I switch from 245/35/20 to 245/30/20?
#36
#38
After some planning, here's my plan for the next phase this summer:
Change to 245/30/20 Falken452 tires on the front. Change from Tein 350Z H-tech's to Eibach ProKit for G35 Coupe. Since the ProKit drop should be pretty even based on my research, I will also replace modded springmounts with new springmounts. Camber kits...since the drop and tire profile will be slightly lower, will that be leave me room for more positive cambers?
