3M di-noc carbon fiber vinyl vs. Neffy Wrap carbon fiber fabric - PICTURES
Old Feb 14, 2010 | 04:50 PM
G35Papa's Avatar
I'll have some pics up later today. The clear coat is drying right now
Old Feb 14, 2010 | 11:50 PM
G35Papa's Avatar
I over did it on the clear. The more you add, the darker it gets. What you see below is 3 coats of the clear. I'd say do at the most 2. With 2 you can still see the detail but 3 it gets too dark.
I used Duplicolor clear top coat but you can use any acrylic clear really.
I'm going to try this one more time so I can get a good feel for the difference between the oem and one with a clear coat.
Before
After (shift **** added for comparison purposes. Shifter was left untouched)
Old Feb 14, 2010 | 11:54 PM
ATL_Red_G35's Avatar
^I like the raw/non cleared look better. Cleared looks muddy.
Old Feb 15, 2010 | 12:04 PM
Calvin's Avatar
Overglorified Altima
Yah, from what I can tell I like the dry look better. But you did say you oversprayed it, so it might look better with 1-2 coats. Post up!
Old Feb 15, 2010 | 12:22 PM
parhamm1's Avatar
So how easy is this stuff to mold and work with....? I'm going to be a noob with this stuff, but wanted to order some and see what I could accomplish.
Old Feb 15, 2010 | 12:24 PM
Calvin's Avatar
^^^really easy to work with when heat is applied. pick up a heat gun from home depot.
Old Feb 15, 2010 | 12:25 PM
G35Papa's Avatar
You can buy a sample of it for around $8 shipped and play around with it. This stuff is pretty forgiving.
I put some on something else last night and sprayed it with a single coat
^that sounded dirty!
I'll take some snaps in a bit
Old Feb 15, 2010 | 12:26 PM
Calvin's Avatar
How big is the sample?
Old Feb 15, 2010 | 12:44 PM
G35Papa's Avatar
12"x12" for $10 is the biggest sample I've seen.
Old Feb 15, 2010 | 09:43 PM
Calvin's Avatar
^^^should have had the weaves on the pull and cover going the same way.
Old Feb 15, 2010 | 09:53 PM
G35Papa's Avatar
Looks good Cal. The nice thing about this 3m stuff, you can remove it and redo it without any issues. You can make it more sticky by putting a heat gun to it on low just for a few seconds.
Here are some pics of a pen I did with a single coat of clear. What the clear basically does is makes it darker then removes the "grey" color from the product. I think I like the dry look better. My roll is coming this week but it will probably be a few weeks before I start my interior.
Old Feb 15, 2010 | 10:00 PM
Calvin's Avatar
^^^maybe it's just hard to tell because it's wrapped around such a small surface. but still not feeling it. might also just be too hard to capture in a picture? looks better in person?
Old Feb 15, 2010 | 10:01 PM
Calvin's Avatar
i actually like that the neffy wrap is blacker. in the above post you can see that the 3m stuff is more on the gray side.
Old Feb 15, 2010 | 10:27 PM
  #30
G35Papa's Avatar
It does look better in person but still not better than the natural color IMO. I asked for a sample of the neffy stuff but it still hasn't come in. From the pics you posted, the 3M looks more like the real thing?
