The Greengoblin build thread
Old Feb 2, 2011 | 10:51 PM
  #1651
GreenGoblin's Avatar
The goblin resurrection
Originally Posted by xx7sephiroth7xx
^ How difficult is it to install these, Danny?
It's def not the easiest thing. Here is a link to a diy that JasonZ-ya did on my350.
http://my350z.com/forum/brakes-and-s...-bushings.html
Originally Posted by JOKER
^^wouldn't those bushings transfer all of the vibrations to the frame and make car loud as hell?
I lost all comforts in the car, if it does it would not bother me one bit. I am sure it can't be louder than my dual 3" aps exhaust.
What are those gonna do for u??
They help bring your suspension geometry back to where it should be when you lower the car.
Old Feb 2, 2011 | 10:55 PM
  #1652
Frankieg35's Avatar
Omfg that is a crazy big project!!
Old Feb 2, 2011 | 11:02 PM
  #1653
Not really, just a few hours of time foo. lol
Old Feb 2, 2011 | 11:36 PM
  #1654
JOKER's Avatar
CLUB MODERATOR
Sounds like it might be a good choice for you. But I see allot of people showing interest in these solid bushings and not realizing that a role of a bushing is to reduce noise and vibration, and solid material don't do that very well.
This is a good option for a drift or a race car tho.
quick question on a 350Z thread.
Why is it important to mark the driveline position on a pumpkin? What diff does it make?
Old Feb 3, 2011 | 12:47 AM
  #1655
erklep's Avatar
ive done literally hundreds of those bushings. we had a recall on them on the altimas over the past few years. if your car has ever seen salt(living in florida, i doubt) it can turn out to be a pita. we had a special bushing tool that was basically a 1/2 inch threaded rod with a cap on one end and you would use your impact on a nut on the rod and it would pull the bushings out of the subframe. but somehow some managed to still not come free and thats when you gotta get real creative! best thing is spray them down with PB the night before and use some heat and/or air hammer
Old Feb 3, 2011 | 01:00 AM
  #1656
nyqueenz's Avatar
Found a pic of what my lower shroud looked kinda like. I had to trim mine a little bit more, but you get the idea.
Uploaded with ImageShack.us
wow how did u get that outof the housin..?
Old Feb 3, 2011 | 01:15 AM
  #1657
SxExCx's Avatar
^dremel
Old Feb 3, 2011 | 08:33 AM
  #1658
I very much doubt that these specifically will increase noise. On moving parts or parts that contact moving parts... then yes. This will remove the mushyness of the rubber bushings, and stiffen up the rear. It will also correct the angle of the suspension some, now that the car is lowered.
The reason for marking the drive shaft is to avoid vibration, they are balanced.
Ya I can only imagine, but I have the tools here and an extra sub-frame to test a few methods on. Thanks for the advise tho.
Old Feb 3, 2011 | 08:47 AM
  #1659
4DGS's Avatar
Really dig the shaved bezels.
Old Feb 7, 2011 | 01:50 PM
  #1660
Lights are ready to paint, I will do that tomorrow.
Old Feb 7, 2011 | 01:51 PM
  #1661
Some work more r&d for the heater delete, and maintaining temp with working t-stat.
Old Feb 7, 2011 | 02:08 PM
  #1662
SxExCx's Avatar
^I have the same workbench!
Old Feb 7, 2011 | 02:21 PM
  #1663
Noice see great mind thing a like.
Old Feb 7, 2011 | 02:48 PM
  #1664
sexyrob's Avatar
awesome work. I love that heater delete.
Old Feb 7, 2011 | 02:49 PM
  #1665
Frankieg35's Avatar
So your not running heat in your car?? Not like u really need it in Florida.. lol
You have already rated this thread Rating: Thread Rating: 13 votes, 5.00 average.
