RRYDE Custom Engine Bays
Aug 16, 2011 | 11:55 PM
  #226
thanks man ^^
Reply 0
Aug 17, 2011 | 12:00 AM
  #227
Love Dal's polished ARC STB with burned ends...
..gives me an idea....
Reply 0
Aug 17, 2011 | 05:43 AM
  #228
This is next on my list... really want to dress up my motor like crazy. Just don't have that flair & know how that RRYDE does when it comes to engine bays.
Reply 0
Aug 17, 2011 | 11:05 AM
  #229
Quote: http://www.weapon-r.com/products/106...-tank-24-fl-oz
is ^^^ the correct coolant tank you guys are running if not can you please post a link so i can order it asap thanks !
that looks wayyyy better than that box looking one Weapon R sells for our cars.....is that one still plug and play?
Reply 0
Aug 18, 2011 | 10:03 PM
  #230
im pretty sure .. they also make one thats a direct fit for our cars but isnt the inlet on top of the can ???? i heard there were issues with that and someone posted that link above and said that was was better cause its on the bottom ...
can someone please confirm before i make the order ????
Reply 0
Aug 18, 2011 | 10:11 PM
  #231
i just ordered the NRG PS tanks and the weapon R coolant 24oz tank with the inlets on the bottom :-)
now i have to find the circuit sport catch can and throw my nrg one away it SUCKS !!!
Reply 0
Aug 18, 2011 | 10:56 PM
  #232
The Cusco and Greddy catch cans also work very well
Reply 0
Aug 18, 2011 | 11:04 PM
  #233
one day i might be able to have a nice one like this
Reply 0
Aug 19, 2011 | 12:01 AM
  #234
Quote: The Cusco and Greddy catch cans also work very well
+1, there is something to be said for doing things a little differently
Reply 0
Aug 19, 2011 | 12:25 AM
  #235
Quote: i just ordered the NRG PS tanks and the weapon R coolant 24oz tank with the inlets on the bottom :-)
NRG PS tank has some major issues on the sedans...me and another member on here tried em with no luck. for some reason it didnt work at all. LMK how that goes for you
Reply 0
Aug 19, 2011 | 12:28 AM
  #236
there's a few sedans running them without any problems... also there is no difference between the coupe and sedan power steering system, pump, or tank. it's all the same. as long as it's installed properly and the correct amount of nissan's power steering fluid is replaced it will work fine.
Reply 0
Aug 19, 2011 | 12:47 AM
  #237
NRG recently revised their PS tank. I believe that the reason why its no longer working on some Sedans, but works on all Coupes who have installed the new version is because the 5AT Sedan doesn't have a PS cooler. The exact tank that Gabe tried to run on his car is now on a Coupe's car with absolutely no issues. The only difference between the two Sedans that it has not worked on (both 5AT) and the Coupes are the lack of a PS Cooler. If we can confirm that it works on a 6MT Sedan (which does have a PS cooler) then we will know for sure.
Reply 3
Aug 19, 2011 | 12:50 AM
  #238
whoa, good info! +1 for the alley boys!
Reply 1
Aug 19, 2011 | 01:32 AM
  #239
Quote: NRG recently revised their PS tank. I believe that the reason why its no longer working on some Sedans, but works on all Coupes who have installed the new version is because the 5AT Sedan doesn't have a PS cooler. The exact tank that Gabe tried to run on his car is now on a Coupe's car with absolutely no issues. The only difference between the two Sedans that it has not worked on (both 5AT) and the Coupes are the lack of a PS Cooler. If we can confirm that it works on a 6MT Sedan (which does have a PS cooler) then we will know for sure.
Marcus hit it right on the head. Gabe's car didn't like that tank... not one bit. And to think, we drove to and from Dallas with that tank installed.
Reply 0
Aug 20, 2011 | 08:20 PM
  #240
yea i have the 6mt sedan so will see how it works .. i ordered it and should be here next week sometime and then im going to polish it then install it ... hopefully everything works out for me ....
Reply 0
6  12  13  14  15  16  17  18  19  20  26
