LS1 Drift Build 'Nuff Said'
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jul 28, 2011 | 12:29 AM
  #31
andrewyfang's Avatar
Looking forward to it! Z was always clean, now it's going to be a beast.
Old Jul 28, 2011 | 12:33 AM
  #32
jookyshank's Avatar
I haz hugz to givez
Old Jul 28, 2011 | 01:05 AM
  #33
eurodre's Avatar
all that work and we didn't get to see a single picture of your rock tight body putting in sweaty work?
no care.
Old Jul 28, 2011 | 01:07 AM
  #34
jookyshank's Avatar
I haz hugz to givez
^^ You are an odd fellow aren't ya?
Old Jul 28, 2011 | 01:22 AM
  #35
TIAN's Avatar
Hold The Line
In.
Old Jul 28, 2011 | 01:30 AM
  #36
Royal_T's Avatar
Thanks guys for the kind words this is why I do this.. Thanks
Originally Posted by ConradoR
Subd. Great start, try to keep up that high level of detail throughout the build, it will def. help a lot of members who plan on doing the ls swap in the future.
Thanks for sharing!
Thanks,, That is the plan to keep it really detailed, hopefully I can help out a lot of people..
Originally Posted by GreenGoblin
So how many months ahead oh these pics are you... :P
Well I tried to stay way ahead of the pics so you guys have something to look forward to every week.. I'll just say this.. The car is at the shop now getting its front tube chassis and cage work done
Been looking forward to you making this thread Edafe!! Subscribed.
Thanks bro, hope you wont be disappointed..
Originally Posted by LordFappington
Yeah its jack tam i sent you a request
Yeah I sent you a long message back you did not get it
Originally Posted by ShanesG
Awesome Edafe, can't wait to see the progress!!
Thanks bro..
no care.
hahaha Dre, I have a pic that you will like.. So stay tuned..
Old Jul 28, 2011 | 01:53 AM
  #37
eurodre's Avatar
Old Jul 28, 2011 | 02:12 AM
  #38
jookyshank's Avatar
I haz hugz to givez
FUUUUUu why did I come back to Dre's response...now I'm gonna loose sleep
Old Jul 28, 2011 | 01:19 PM
  #39
Matzo Ball's Avatar
in for the epic win.
Old Jul 28, 2011 | 02:51 PM
  #40
Epidel's Avatar
Looks like this thread is going to be good, in for updates!
Old Jul 28, 2011 | 02:57 PM
  #41
ATL_Red_G35's Avatar
sweet built Edafe. Thanks for the updates bro. Can't wait to see what you got instore for that thing
Old Jul 31, 2011 | 06:12 PM
  #42
BmoreIPdriver's Avatar
want to see finished product.....
Old Jul 31, 2011 | 11:32 PM
  #43
Royal_T's Avatar
Okay folks here I am with week 2 update.. I plan on updating every Sunday...
STAGE 1: Phase 2 'Cam/Pulley Install'
Lets start this off with the Beer of the week.. We have here folks 'Mississippi Mud' Its a Black & Tan beer which has a little kick to it.. I also love the bottle it comes in, makes me feel like I should be sitting on a porch throwing meat to alligators..lol
Okay what I am installing today is a MS4 Cam from Texas Speed Shop and a ASP Harmonic Balancer. Now I bought the the Texas Speed Shop Camshaft package that comes with a Texas Speed Hardened Chromoly Pushrods and Dual Valve Sprigs.. I will install those later..
MS4 CamShaft Package = $699.99
ASP Harmonic Balancer = $214.99
Okay lets get started on removing the old stuff. First on the list is the balancer. You will need a 1" socket to remove the bolt that holds it in place..
A braker bar is a must when it comes to taking off this damn bolt..
Again Advance Auto Parts come in handing when I needed to rent a tool.. I went there to pick up a Pulley puller. This tool is a must and really the only way you can actually get this dang pulley off the engine.
Tool set up...
The claw hooks grab the pulley and pulls it away from the engine.. As you begin to tightening the bolt it starts to get harder and harder to do.
That is when a pole comes in handy...lol
You know you are doing it right when you start to see silver from behind the pulley.
Just to give you an idea of the size difference between the ASP pulley and OEM pulley.. ASP gives you around a 15% more power, every bet counts..
Next we can remove the timing chain cover.. This requires you to use a 10mm,, really easy..
Bam!!, look at the LS6 oil pump and LS2 timing chain... Good stuff..
Now we can remove the timing chain sprocket, Unbolt the 3 cam gear bolts and remove the gear, letting the chain droop down into the oil pan for now
Next is the retainer plate
Next you'll see a black/brown cam retainer plate behind the gear, held on by 4 10mm bolts. Unbolt and remove this too.
remove, the bolts..
Out with the old cam....
And in with the new.. The MS4 cam is a 239/242 .649"/.609" Camshaft.... Oh yeah...
Now it is time to prep the new cam for install. Coat the whole thing with fresh motor oil, and transfer your 3 camgear bolts (or waterpump bolts if you were using those) to the end of the new cam so again you have a handle to grip onto.
Now take your time installing the new cam, and keep on coating the cam with fresh oil as you go..
Almost done,, the 3 camgear bolts come in handy towards the end when you don't have nothing to grab onto,, so def do this..
Once in, re-install the cam retainer plate and its 4 10mm bolts. I usually put some locktite on the 4 bolts and the GM torque spec on them is 18lbft.
Then install the timing gear, and torque spec on these is 18lbft as well.
Now since the timing chain cover was off, I decided to spice it up some.. So I painted it a black crinkle. I think it turned out great.
Now for the time being I used the OEM balancer bolt to install the new ASP balancer. Now the Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) needs to be torqued to 240lbft. And then remove bolt and replace with an ARP balancer bolt and torque to 37lbft. I will do this later once tranny is installed.
Well hope you enjoyed this weeks post...
Total spent: $2,464.98
STAGE 1: Phase 3 'rocker arms/valve springs/ head Install'
Old Aug 1, 2011 | 01:42 AM
  #44
jookyshank's Avatar
I haz hugz to givez
Best build thread (with details) EVAR! (haha gonna keep an eye on the spent $)
Old Aug 1, 2011 | 02:30 PM
  #45
sofa king's Avatar
Wow! Cannot wait to see this thread play out!
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
