LS1 Drift Build 'Nuff Said'
Rating: Thread Rating: 4 votes, 5.00 average.
Old Mar 17, 2015 | 09:34 AM
  #526
Royal_T's Avatar
Originally Posted by SIKKI
That's killer! You are creating a monster!
Thanks for the kind words
Old Apr 15, 2015 | 10:32 AM
  #527
Royal_T's Avatar
So no real updates from me really, car is just awaiting some parts to arrive so I can wrap up my brake lines.. At the moment all the front stuff is complete need to run the rear stuff now. After that is complete I can finally take it to the alignment.
For now tho here are some pics:
Old Apr 15, 2015 | 11:38 AM
  #528
Texasscout's Avatar
Curious, have you load weighted the car yet? What is the weight distribution?
Old Apr 18, 2015 | 03:32 PM
  #529
Royal_T's Avatar
Nope have not checked on the weight distribution.. But it is something I will do..
Old Apr 18, 2015 | 10:35 PM
  #530
SIKKI's Avatar
Thumbs up
It's alive!!! It's alive!!!
Old May 22, 2015 | 05:59 PM
  #531
Royal_T's Avatar
Okay guys finally some update. I finally was able to finish my brake lines, with family life, work it was hard to get to the car. I just ordered parts every week until I had everything to smash it out in pretty much one day.
Before we get started I decided to showcase this Cognac instead of beer. (since I have not had a decent beer in month). Anyways, my mother In-law picked up this Hennessy Pure-White when she went on a cruise. They don't sale these state side so it was a treat. This is probably the smoothest Hennessy I have ever tried..
Okay, so I got a little OCD with the brake lines. I made bulk head fittings for the firewall and the rear wheel wells. This way if I need to do anything it well be quick and easy and over all its just a cleaner look.
Going to be running -3an lines and fittings..
Okay lets getting started, have to have my guilty pleasure
Started my installing the new -3an fittings on the BMC
added a little 90 degree bend right here so it would not hit my filter on my heads.
Added to bulkhead fittings here. One goes to the rear and the other goes to the passenger side.
This is the view behind the firewall to run to the passenger side.
And out the other side, did not want a lot of clutter in the bay..
Ran two Banjo fittings for the fronts..
Fronts are done..
To do the rears I had to make a tube straighter for the hard lines that go to the rear. Did not want to buy a $200 tool so made my own.. Came out good..
Started from the firewall and heading to the rear.
And yep found me some black hardline.. Just had to do it..
Coming up on the tee.. yeah I need to clean the car.. once everything is done interior will be cleaned
Here you will see both the tees for my MBC and my Hydro E-Brake
Had both sides running the the bulkheads in the wheel well..
Close up
And the other side of the wheel well
And rears done..
Now just have to bleed them and get ready to head to a alignment shop.. But before I go I will swap out my Clutch Master Cylinder for the Wilwood 7/8" master cylinder that Sikky sales. Reason for this is the OEM Cylinder can't handle the T56 clutch..
Tell next time guys..
Old Aug 31, 2015 | 01:11 PM
  #532
alessandro's Avatar
I love ittt
Old Sep 13, 2015 | 11:05 AM
  #533
Royal_T's Avatar
First off no update yet really... I ditched the overfenders I have for the front and rear and have some new ones being made fresh out of mold. Reason for this decision was due to available for replacement parts. Old overs were from NZ and would be hard to get spares so hooked up with a guy in the states.. So should have those soon.
Pics of the overs:
Old Oct 20, 2015 | 01:25 PM
  #534
Royal_T's Avatar
A little tease on whats going on.. New Fenders are here..
Old Oct 24, 2015 | 08:32 PM
  #535
driftsucky's Avatar
I noticed some different suspension going on there. Did you ditch those stanceworks coilovers? If so, why...and where are they? I always liked the idea of those for low-ness and driftness but just kinda being amateur on both.
Old Oct 25, 2015 | 11:50 AM
  #536
Royal_T's Avatar
Yeah I got rid of those a long time ago.. I have no idea who has them now.. I really do wish I kept them tho.. since I was really the only one with them.. I am running the K-Sport ones now.. Which I will try out for a little bet.. If I don't like them I will change them up..
  #537
Royal_T's Avatar
Here is a little tease of the fronts... Still have to get a alignment and get my fronts sitting at -4.5 camber.. Then I will add a spacer to finish her off... This just give you a idea.. Current front specs are 18x9.5 -22
If you look at my signature it clearly states how I feel about spacers.. Well since I built these wheels to go with my other fenders I will definitely have to get some spacers for these fenders, which I hate. I will eventually rebuild them so I wont have to run spacers but I guess I better remove my sig for now... lol
Old Nov 1, 2015 | 12:43 PM
  #538
Royal_T's Avatar
So did some measuring for my wheels and came to the conclusion that I will run 25mm spacers rear and 38mm Spacers front..
Also going to lower the rear some..
Also got my bolts in that I will be using for the overfenders.. Decided to get some clean burnt titanium ones..
Old Jul 6, 2017 | 03:01 PM
  #539
Royal_T's Avatar
I'm Back!!!!!!!!!!!!!!!!!!!!!!!
Been way to long without a update.... Life got the best of me and the project sat for a while.. Had some more issues with PCM tune and wiring issues.. But now that is all fixed and we can start moving forward with wrapping things up..
This is how the car looks as of right now.. Car is wrapped in this picture.
Decided to go with a Hexis Wrap, color is a Gloss Saturn White Glitter Vinyl Wrap.. Looks killer in the sun.
As you can tell from the pic, I finished up my side splitters and also my wing endplates.
With all that being said, tried to go get a alignment the other day, but did not work out good, due to my car being so low and need a in-ground unit to get it done..
But once that is complete I should be ready to start doing some mad skids...
So stay posted.. I also have a vid of me driving out of the garage. I will have to put it up on here as well..
But get ready for some updates..
Old Oct 9, 2020 | 11:27 AM
  #540
Royal_T's Avatar
What’s up y’all. It’s been a long time since my last post so I decided to post up a little “Car Check” video for y’all. Enjoy the full walk around on my car. A lot of cool stuff is happing so stay tune for more stuff. Enjoy.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
9tray turbo
Sep 29, 2015 10:22 PM
ncg35guy
Sep 24, 2015 04:53 PM
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
