Project G35 G35Driver's Official Project Car forum.
G35 ls2 swap so cal
Old May 24, 2012 | 05:33 PM
eric350gt's Avatar
the motor im talking about is the cast iron version of the ls i want a truck block cause im gonna go tt and nitrous
Old May 29, 2012 | 12:21 PM
Brew_haha's Avatar
You prob wont be able to fit twins on there unless its a rear mount setup. Everyone i know is doing single setups and having to notch the frame rail. You will also need ARP everything if you are wanting anything over 650.
Old May 29, 2012 | 01:45 PM
eric350gt's Avatar
yeah i was thinking of the rear mounting twins but that wont be for a while, by then im sure someone will have perfected a kit for this swap. As for ARP everything what exactly are you refering to cause i picked up arp head and rod bolts, also is there any brand of bearing you recomend?
Old May 30, 2012 | 11:19 AM
Brew_haha's Avatar
Not sure on bearings i just had the machine shop make sure they were good when they pressed the rod bolts in.
Old Oct 6, 2012 | 02:23 PM
sh0rtys463's Avatar
Eric did you ever do the swap?
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
TheefrshstVQ
Jul 26, 2015 09:37 PM
laksjd84
Jul 24, 2015 05:12 PM
