Diy Tools
Old Jan 11, 2008 | 05:58 PM
Drewer's Avatar
Originally Posted by Jeff92se
I love my rhino ramps. But stands, where do you guys place them?
See here.
Old Jan 11, 2008 | 06:12 PM
sydg35's Avatar
I've got a full metric Craftsmen set that I got years back, has the standard 1/4, 3/8 & 1/2 socket wrench and pretty much every socket and box wrench you would need to work on a Japanese car. I'm not sure if Sears still carries it, but I figured I'd never own an American car, so what the hell would I need a bunch of SAE tools for. I did pick up a set of flare nut wrenches for working on fuel and brake lines, they're nice cuz you can'r round off the nuts. and a brake piston tool is good to have.
Joaquin03's Avatar
Staff ALUMNI
Originally Posted by citymunky
I have a cheap Walmart ratchet set, that I keep in my car. All my tools are at the base DIY shop.
+1... gotta love the military
Old Jan 11, 2008 | 06:16 PM
istan's Avatar
Got to love Walmart. $20 and I can get most things done. +$20 Craftsman wrench set and I'm set. Torque Wrench and 21mm Deep Socket for those pesky lugs.
All in my car at all times. Along with a set of mech gloves, dirty shorts, shirt, jacket.
Old Jan 11, 2008 | 06:57 PM
w0ady's Avatar
fgc moderator
ive got the basics right now - screwdrivers, ratchet set, pliers, etc.
i think when i start serious list - torque wrench, low profile jack and 4 jack stands.
Old Jan 11, 2008 | 06:58 PM
Bigd2k6's Avatar
some misc essentials: drop light, extension magnet, breaker bar, deadblow hammer, good needle nose pliers
Old Jan 28, 2008 | 10:18 PM
SVLRx's Avatar
i have the craftsman tool kit, not sure how many pieces but it's a lot (~200). I added a craftsman bit set, has every type bit i might use (torx, screw driver heads, and small sockets) and i have a porter cable for polishing, and an oil filter wrench.
Old Jun 19, 2008 | 09:18 AM
Project's Avatar
I think everyone hear forgot the most important tool a man can have...especially when dealing with an older car......a BIG hammer....works wonders
Old Jun 22, 2008 | 12:54 AM
shipsaeki's Avatar
you guys are using standard sizes on japanese cars? cmon, we don't own fords or chevy's here!
I built my collection over the past 5 years and have accumulated about 15 grand in tools... but the most used on our cars are:
Sockets:
10mm
12mm
14mm
17mm
19mm
21mm
Wrenches:
14mm
17mm
19mm
Old Jun 22, 2008 | 02:15 AM
SDGeneralCounsel's Avatar
basic hand tools, rachets, torque rench, jack and stands, drill, dremmel. I think that's all I've used thus far.
Old Jul 1, 2008 | 03:25 AM
serturbo's Avatar
Anyone have any advice on trying to remove OEM 19's without a air gun and compressor? I tried using my longest ratchet and deep dish socket and I ended up putting nicks on the rim around the lug nut. I couldn't stablize the socket around the nut while putting enough pressure to loosen it. I was so pissed. I should have noob tatooed on my forehead. Any help would be appreciated before I try to remove the other 3 wheels and not damage my new Works
Old Jul 1, 2008 | 11:25 AM
afr0puff's Avatar
Supa Dupa Moderator
I fvcking love this thing. It torques high enough to remove wheel lugs torqued to 90 lb/ft. But make sure you are using the right size deep socket. You don't want any play at all or else you will strip the nut over time. I made the same mistake you did on my original wheels. Cover the outside of socket with a single layer of duct tape.
But I think your biggest problem was that the nuts were over-torqued. Only supposed to tighten to 80-90 lb/ft. That doesn't take THAT much effort to loosen by hand.
Old Jul 1, 2008 | 12:25 PM
serturbo's Avatar
Well the rear tires were replaced by Discount and I know they have a history of over torquing lug nuts. I had to step on the ratchet for the lug nuts to loosen up. Using duct tape sounds like a real good iea. Thanks a lot for the advice
Old Jul 1, 2008 | 01:05 PM
Scrooge's Avatar
I was thinking about getting a 3/8 impact torque wrench for engine duties and interior work. Maybe from snap on or ingerolls rand which have 150 ft lb of torque.
Old Jul 11, 2008 | 02:27 PM
  #30
G SEDAN's Avatar
omg drool
I've been wanting that but havent had the chance to go get it...home depot here i come!
