Reviews Reviews of specific modifications, posted by members
Unlimited Tuning Y-Pipe
Old Oct 12, 2004 | 05:36 PM
G35PhatS4's Avatar
G SQUAD
Mod: Unlimited Tuning Y-Pipe
$: $320
DIY: yes (if you can get your car up); Shouldn't cost a shop more than $40 to install. I paid the guy $30 cash.
Difficulty: Easy (6 bolts total)
Time to install: <1hr on your own. Bodyshop did it in 10minutes
Overall value: 4 out of 5
Review: "Butt" Dyno tells me it seems to have open up a little bit more on the low end. Sound difference is slight, and not too loud which is what I'm going for. I went for something subtle and it was a PERFECT fit. The guys that installed it even noted the nice welding job and how nicely it fit.
If you plan on keeping your stock exhaust, this is probably a good mod...without having to do too much. [img]/w3timages/icons/smile.gif[/img]
You can purchase this from www.UnlimitedTuning.com
6MT DG Coupe | Prem | NAV | Aero | XM | Z-tube | Clears | Aluminum Pedals | UT Y-Pipe | 40%Huper | Graphite RH J5 Pro 19"
Old Oct 12, 2004 | 07:11 PM
wizawuza's Avatar
Re: Unlimited Tuning Y-Pipe
you talk about the sound difference, but how about at each rpm range? At the low end is it pretty much the same, but then only a slight increase at high rpm, or what?
Thanks.
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Oct 13, 2004 | 10:00 AM
G35PhatS4's Avatar
G SQUAD
Drove more last night and this morning... from my observation since it's still fresh on my mind... You don't hear too much of a noise difference until you start to open her up. So around 3.5k+ to WOT... it sounds great and has added a slight growl to it. I personally really like it IMO. But I definitely feel it pull a little more with the installation of the Y-Pipe.
Old Oct 14, 2004 | 01:15 AM
Vic's Avatar
Vic
isn't that our stock exhaust system has Y-pipe too?
You said that this Y-pipe will fit the stock exhaust, but will it fit other exhaust too (Nismo, Fujitsubo)?
TB/Black, 6MT coupe
Old Oct 16, 2004 | 01:46 PM
ChromiumBlue's Avatar
yes, i have the fujitsubo y-pipe which i picked up about a month ago, 350 total, i couldnt pass it up. however, im not installing it yet b/c im waiting to buy an actual exhaust for the rear half of the car. I was thinking maybe rs-r or fujitsubo. but yes it will fit any exhaust that fits to the oem y-pipe.
Old Oct 22, 2004 | 05:13 PM
KAHBOOM's Avatar
that can't be right... There is no way that the torque and HP lines should cross past 5552 RPM.. am I seeing that right? It looks like is crosses after 5500
2003.5 G35C 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old Oct 23, 2004 | 06:17 AM
Vadian's Avatar
The HP and Torque figures are on difference scales thats why it isn't crossing at 5252rpms. =)
Old Oct 24, 2004 | 08:57 PM
636Racer's Avatar
i dont know how to really read dyno graphs..but......
can a y-pipe increase your hp by 20rwhp?
Formula Hawaii.Drift Session.Mid Pac Road Racing Association.Bi Tron
Old Oct 28, 2004 | 12:13 AM
boost21psi's Avatar
from what i have heard.. no way.. 20 wrhp.. i wish
Old Oct 28, 2004 | 08:42 PM
636Racer's Avatar
well...can someone get UT to please clarrify?
My Sources
Old Oct 29, 2004 | 09:04 AM
GUnitCar's Avatar
Let me place my review on the UT ypipe.
Amazing fit,finish and quality. Installation was quick and painless, includes all hardware (bolts, gaskets).
Power is definitely evident in the mid to upper power band.
And the sound is no different under normal driving conditions but once u drop the hammer, the sound is intoxicating....
As for the dyno chart gain, (if you search the boards) it was noted that the dyno graph shows the worse stock run vs. the best run with the ypipe.!??! You should expect a minimum of 7-9hp gain. on a stock G.
GREAT PRODUCT and recommended.
Old Nov 2, 2004 | 01:56 PM
BigRon's Avatar
How about weight savings? Anyone drop this and a stock Y-pipe on the scale to measure the difference in weight between the two?
If not, certainly some of you have handled both Y-pipes and can give some description of the weight difference.
'05 IP(or ?) 6MT... ...Never too soon to think about modifications!!
Old Nov 9, 2004 | 08:51 AM
GUnitCar's Avatar
According to thier website, its a 3 lbs savings over stock.
Old Nov 11, 2004 | 07:52 PM
UnlimitedTuning's Avatar
Average hp gain on the YPipe is about 9-12, we had an open invitation when we dynoed the YPipe, you will see a bigger increase if your car is running at an optimal level vs. lean or rich, thanks.
Old Nov 14, 2004 | 06:41 PM
beavis's Avatar
Sorry to ask again, but I'm probably getting the UT y-pipe. Are you sure the sound is not raspy ? I've heard of other y-pipes getting a raspy sound. I would like to retain a close to stock sound if possible a little louder and deeper is OK, but just not fart can.
Thanks
