SFL G CLUB South Florida G35's + G37's
Fender Rolling
Old Feb 20, 2008 | 04:45 PM
GreenGoblin's Avatar
The goblin resurrection
Mike is making the tool, but in the mean time I could ask my buddy to borrow his and we find a spot and do a few
Old Feb 20, 2008 | 05:25 PM
Boston's Avatar
^ Let me know when and where. Thanks
Old Feb 20, 2008 | 06:48 PM
2slo2bfurious's Avatar
I'll pitch in too, sooner or later I'd need them rolled anyways. Have you guys seen the DIY roller thing that you can make from a VW jack. Looks pretty easy, but I can't weld.
Old Feb 20, 2008 | 09:46 PM
are you serious ^ you saw my welders the other day lett me know what I need to do
Old Feb 21, 2008 | 12:14 AM
I'm sure one of you guys have access to scrap or a cnc machine or something... probably cost plenty less than 250....
Old Feb 21, 2008 | 06:20 PM
imRACERX's Avatar
doesnt look too diff to make. anyone on it?
Old Mar 6, 2008 | 04:54 PM
Dakkerz's Avatar
If I wasn't so far north of you guys I'd chip in since I need my fenders rolled.
Old Mar 6, 2008 | 05:44 PM
YlliW's Avatar
I've rolled plenty of fenders with a baseball bat.... and I already have the bat
Old Mar 6, 2008 | 05:58 PM
YlliW's Avatar
** WARNING**
IF YOU DONT KNOW WHAT YOU ARE DOING YOU WILL FVCK YOUR **** UP.
Step 1: READ WARNING
You have to jack up your car and put it on a jackstand to work at it, unless you want to just remove your wheel.
Step 2: Find an old baseball bat and some fat friends
Jack the car up and place the bat between the tire and fender, then lower the jack completely so that the bat is now stuck between the tire and fender. Make sure you place the bat at either the front or rear of the rear fender.
Open your trunk and get a few of your bigger buddies to sit on the trunk ledge so that the car sinks and puts even more pressure on the bat between the tire and fender.
Step 3: Roll it!
Find a trustworthy friend and have him hold the bat and press down on it, getting it as vertical as possible. Turn on your car and keep the door or window open so you can communicate with your trusty friend. If you placed the bat at the front of the fender, but your car in reverse and slowly roll it backwards while your trusty friend pressed the bat and moves with it as it rolls along the fender backwards. Do the same if you placed the bat at the rear of the fender, except with the car in 1st gear or Drive if you have a step.
Repeat this about 3 or 4 times. Jack up your car and remove the bat. Your fender should now be rolled!
TIP: With a heat Gun warm up the fender to help prevent Paint damage.
Old Mar 7, 2008 | 10:32 AM
broke_as_ajoke's Avatar
ok bro i read what u said.. but i don't have that many friends hehehe.. 3 fat guys in the trunk + 1 trust worthy friend in the car + 1 trust worthy friend holding the bat + 1 another to TURN the bat = 6 friends.. aww dang.. i guess me my mom and pop will have to do for now.. maybe i can get my too cute sister to help out.. we are still short 2 people heheheh.. i'll call the fire department and see if they can come out hehehe
Old Mar 7, 2008 | 01:02 PM
really only need 2 people and some weight in the trunk
Old Mar 7, 2008 | 02:18 PM
iamericgee's Avatar
DUDE !!! rubber mallet thats all
Old Mar 7, 2008 | 02:54 PM
YlliW's Avatar
true, but its more fun this way
Old Mar 7, 2008 | 03:17 PM
express705's Avatar
ahhahahahahah
Old Mar 7, 2008 | 03:46 PM
  #30
With a rubber mallet you will run the risk of making your quarter panel, wavy and you should have a dolly on the out side wrapped in some serious tape to prevent scratching the tape
