GreenGoblin
The goblin resurrection
close
- Join DateOct 2006
- LocationIn my garage
iTrader Positive Feedback100
iTrader Feedback Score(66)
Liked:187 Times in 95 Posts
Mike I am good to go for now just need to order a few things but no hurry, will order Tial 50mm bov, walbro 255, and oil pan spacer
Quote:
are you gonna go w/ the Tial wastegates also?
GreenGoblin
close
- Join DateOct 2006
Quote:
I wish those bad boys are so $, I am gonna get the open dumps for sure thoOriginally Posted by escobar929
Aren't the greddy wastegates = tial?
You should get some heat wrap for the starter and a little for the fuel lines would be good too, oh and t-bolt clamps too!
GreenGoblin
close
- Join DateOct 2006
ya heat wrap for sure
I still have a good mid pan if you want to mess around with your own set up. I just dont see doing all that for a return. The spacer kit will include spacer and the oil pick up spacer. However I dont think it comes with a longer dip stick. You already have the extra volume from the cooler and lines. What do you say I just weld some bungs on both sides of the pan and you give me yours when we do the swap?
GreenGoblin
close
- Join DateOct 2006
Ya thats true about the extra oil cause of the cooler. We will see when we start tearing into it.
GreenGoblin
close
- Join DateOct 2006
update: upgraded oil return lines, tial 50mm bov, and walbro confirmed.
I installed the headers on my mock up motor and with the studs removed if the bolt hole alignment is the slightest bit off I could see where you could have problems. But I suggest we put the manifolds on the mock up motor and see how bad they are. I like it and the bolts are 12mm 12 point bolts. Ive got the part numbers If you need it.
GreenGoblin
close
- Join DateOct 2006
Mike I got the spacer for the hell of it, guy was selling on on my350z for a decient price, I am think of just pulling the motor, I will never forget how ****ty the headers were.
GreenGoblin
close
- Join DateOct 2006
also this way I can ensure the manifold get torgued down properly
