SFL G CLUB South Florida G35's + G37's
Powerlab GT35R ST Kit
Old Jun 5, 2008 | 05:09 PM
escobar929's Avatar
dont bother, go TT. learn from my mistakes
even though it is a better version of the TN kit, it will still bottle neck when you way up the boost
Old Jun 5, 2008 | 05:19 PM
INTENSEPOWER's Avatar
^^ Please explain where, why, and at what psi this will happen. I've yet to see it happen and we've tested the PowerLab GT35R up to 650whp, the PowerLab GT37R up to 700whp and the PowerLab 76s up to 906whp.
Darren
Old Jun 6, 2008 | 12:30 AM
MastaRip's Avatar
Thanks for the info every1.
Old Jun 6, 2008 | 01:03 AM
MastaRip's Avatar
Originally Posted by SlideFox
Didn't realize I was trespassing... Shouldn't this be in the F/I section?
its been there, 0 views and 0 replies.
SFLG35 > FI Thread.
Old Jun 6, 2008 | 01:14 AM
SDGeneralCounsel's Avatar
Originally Posted by mastarip
Ive been looking around at different kits, planning on boosting her soon. I was reading some threads and bumped into this kit:
Powerlab GT35R Kit.
I know for the price I might as well get a TT, but I wanted to know if anyone has every had this, or known someone that has this.
http://www.intensepower.com/pogttukit350.html
From what i've read, you can get as much from this ST than you can from a TT, but thats with any ST if you build it.
Please let me know.
-Haris
On a Z you are very limitted with the TN kit but with a kit with a much larger turbo like this Powerlab kit(s), you can gain as much or more than the TT setups. The weak point of course will be your motor. Generally the main advantage of a TT setup over the Powerlab setup is the lag. these big turbo's have big lag (this is the same problem with any large single turbo setup). A few are running this kit on my350. I would run a search there. I don't know of anyone on G35driver who is running this kit.
Old Jun 6, 2008 | 09:48 AM
escobar929's Avatar
Darren
wow, i didnt know that.
i hadn't seen one w/ more than 500rwhp
thats pretty impressive
Old Jun 6, 2008 | 09:51 AM
express705's Avatar
the video is on yourtube. its REDICULOUS
Old Jun 6, 2008 | 10:02 AM
SlideFox's Avatar
SFLG35 > FI Thread.
I guess the F/I section here on Driver isn't as active as it is on My350z...
Old Jun 6, 2008 | 10:58 AM
mushy's Avatar
SFLG35 ftw
Old Jun 6, 2008 | 12:51 PM
MastaRip's Avatar
yea, thats why I bought this thread up, the Powerlab ST kit is pretty amazing. The fastest G on record has a Powerlab ST.
Old Jun 6, 2008 | 12:58 PM
GreenGoblin's Avatar
The goblin resurrection
Harris you getting it>
Old Jun 6, 2008 | 05:45 PM
MastaRip's Avatar
its not available for 06 g35s yet, they said it would probably be by the end of the year, im just going to save up to 8-9 g's then pick the best one, gona research my a$$ off these upcoming months.
Old Jun 6, 2008 | 07:11 PM
w0ady's Avatar
fgc moderator
have you decided what power you're looking for? powerlab's st is finally another option to the big tt kits like greddy, aps and jwt. if you follow the supra world, you can see big hp cars running both setups. it basically comes down to what sort of powerband you're looking for. the tt has a little less lag like someone else mentioned but the big st really makes power when it gets started. good luck with your search.
btw jose, what kind of problems did you run into with your tn?
Old Jun 6, 2008 | 07:44 PM
MastaRip's Avatar
i dont want to go all out, just looking for at the most 420-425 to the wheels, around there. I am by no means a turbo guru, I have much more research to do.
Old Jun 6, 2008 | 08:24 PM
  #30
^^ Not sure exactly where you live, but Performance Factory, in Orlando, is a PowerLab dealer -- and more than competent when it comes to doing builds of all calibers. Jeremy's the man over there, you may want to give him a shout. My thoughts..
D
