SFL G CLUB South Florida G35's + G37's
Need Battery
Old Apr 13, 2009 | 01:14 PM
escobar929's Avatar
yea, i've never noticed my lights getting dimmed, so i never bothered w/ a cap either
but i have seem other cases where a cap helped w/ the lights dimming
Old Apr 13, 2009 | 02:47 PM
chico305's Avatar
some amp don't required much power, but I notice lots of dimming with gain half way up
hopefully the alt can take it
Old Apr 13, 2009 | 04:33 PM
CLiX`G35's Avatar
what amp are you running? also did you pass a large enough gauge cable, if your cables are too small they heat up and stop conducting as well draining power.....
Also make sure you volt meter your amp.. I don't have the gain even 1/4 the way on my 1000/1 and i make 1000 watts at 28 volume on the head unit leaving me room to clip up to 31. If you don't volt meter your amp and just turn the gain *** you'll end up clipping really bad, as well as sucking massive power because your amp becomes very inefficient.
Old Apr 13, 2009 | 04:40 PM
chico305's Avatar
running a mtx 7801 with 0/1 gauge cables
Old Apr 13, 2009 | 09:01 PM
chico305's Avatar
in other words I could just go buy any other battery from auto zone and it wouldn't make a big difference
for example duralast, autocraft titanium
Old Apr 14, 2009 | 10:34 PM
CLiX`G35's Avatar
I think before even upgrading bettery etc. go to the jl audio site and check out their tutorial on volt metering your amp.
Then proceed to set your gains with a volt meter and after that is set check if it dims.
Unless you are running two 2 ohm subs in series to have a 1ohm load you have less power then it do and should not be dimming as much as you are unless its set incorrectly.
If you wanna spend money on a battery I would buy a Kenetic deep cycle battery or another comparable battery but they are very expensive.
Old Apr 17, 2009 | 05:32 AM
chico305's Avatar
thanks!
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Thebaws11
Nov 30, 2016 12:54 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
