SFL G CLUB South Florida G35's + G37's
brake advice
Old Nov 11, 2009 | 12:15 PM
broke_as_ajoke's Avatar
brake advice
Hey yall,
Can anyone tell me anything about these Centric rotors? I'm on a budget and I can't get the best rotors right now.. So I would apperciate some feed back on this setup.
I have an o7 coupe.. base model.
Most of the other rotors I have seen have black hubs. So, I was wondering is that just a coating. They kinda look like they would rust and produce a lot of brake dust. (that rust/orange color on the rotors)
Rotor and Brake Pad Kit Special!! Cheap Prices with Great Quality, Check it Out!!
https://g35driver.com/forums/brakes-...check-out.html
Just got these today from Z1 racing
Old Nov 11, 2009 | 01:35 PM
twin001's Avatar
Centric rotors are very good. Stoptech uses Centric blanks and machines the slots and/or drilled holes in them....that alone should tell you something about their quality. If they are good enough for one of, if not, the best brake manufacturers out there then they are good for me too.
If you are worried about the coating then just get some high temp brake paint and paint the rotor hat. Nothing but good things to say about Concept Z as well, I bought my Akebono BBK from them.
Old Nov 11, 2009 | 04:14 PM
thanks bro..
Old Nov 11, 2009 | 08:19 PM
mesias's Avatar
I have them for a while already... no problems!
Old Nov 14, 2009 | 04:13 PM
mesias, have u seen any rust on them?
Old Nov 14, 2009 | 07:03 PM
mesias's Avatar
No rust at all anywhere but on the fiction surface in humid days.
Old Nov 14, 2009 | 09:31 PM
w0ady's Avatar
fgc moderator
spray your new rotors with high temp paint before install. your pads will take off any paint on the areas that you use and protect the rest of the rotor from rusting.
Old Nov 16, 2009 | 12:47 PM
cool.. i will do that.. thanks
Old Nov 16, 2009 | 10:39 PM
escobar929's Avatar
i have rotora's on both Gs but ive heard good things bout those
Old Aug 7, 2011 | 04:35 AM
Agent F's Avatar
Hey OP, how did the Z1 Rotors work out for you?
Old Aug 15, 2011 | 07:34 PM
^I have not had a problem with them at all.. it's gonna be soon to buy some more pads i think i will stick with the same brand..
Old Aug 22, 2011 | 09:45 PM
TIAN's Avatar
Hold The Line
Good stuff Sean. How much did it all run you?
Old Aug 22, 2011 | 09:50 PM
i think i paid 550.. for everything.. i have had them for a minute now.. (got them in 09)
Old Aug 22, 2011 | 09:51 PM
TIAN's Avatar
Hold The Line
Word. I need to get some soon. Mine are ready to be changed
Old Aug 22, 2011 | 10:01 PM
ConradoR's Avatar
Centric is legit I'm running centric premium, rotora ss lines, project mu pads, and dot4 fluid, and I would do it all over again.
