SFL G CLUB South Florida G35's + G37's
5th is grinding
Old Dec 18, 2009 | 09:41 AM
arsine's Avatar
5th is grinding
i changed my gear oil a few weeks ago with amsoil 75W-90 and lately ive been experiencing grinding going into 5th at speeds between 35-45. it seems to happen regardless of tranny temp (though more common i think at lower tranny temps) and at lower revs. comments?
Old Dec 18, 2009 | 12:59 PM
ishiftinheels's Avatar
Teh Redhead Moderator
Did it only start after you changed the fluid?
I just recently had to replace my transmission due to 5th & 6th gear grind. 5th would grind regardless of rpm/speed. 6th would go into gear without grinding if I babied it. I replaced the trans fluid but it was too far gone at that point and I had to replace it. I ended up getting an 05 trans with 34k miles on it, and so far no complaints *knocks on wood*
How many miles are on your car? The 06 transmissions are supposed to be a heck of a lot better than the 03's. If you have to get a new trans I would recommend the CD009. But for now, just skip 5th, that's what I did
Old Dec 18, 2009 | 01:01 PM
escobar929's Avatar
mine did it pretty much all the time, i just got used to it
if you're still under warranty, have them replace it w/ CD009
Old Dec 18, 2009 | 01:16 PM
arsine's Avatar
i have about 54k right now, change was done about 4 weeks ago. didnt have any issues before. the fluid looked like **** and definitely needed changing. the grind happens irregularly so im having trouble identifying the problem exactly. under conditions where i anticipate grind, i give the engine extra revs before engaging the gear.
ill mention it to infiniti next time im there, but theyve been pretty ****ty lately about honoring waranty claims, especially since i didnt have my fluid changed there and im not running nissan oil
Old Dec 18, 2009 | 01:46 PM
Just call Infiniti Consumer Affairs and b!tch if the dealership won't honor your warranty. I think the transmission is covered until either 60k or 70k.
Old Dec 18, 2009 | 02:14 PM
arsine's Avatar
ill look into it then if it keeps up, i have an extended warranty. considering changing to a different fluid too
Old Dec 18, 2009 | 07:27 PM
escobar929's Avatar
its your tranny bro, every one gets the 5th gear grind at one point or another
Old Dec 19, 2009 | 03:58 PM
arsine's Avatar
lame, guess ill bring it up when im due for another oil change
Old Dec 21, 2009 | 10:30 PM
thescreensavers's Avatar
Mr.202?
^ if you have anything other then the Nissan Matic bs they might just laugh at you.
Some people have had the warranty taken away on the tranny because they had different tranny fluid then what is recommended " Might cause damage if if you use anything other then Nissan S/J-Matic" something like that in the manual so just a heads up.
Old Jan 12, 2010 | 03:32 PM
Sanclementeg35's Avatar
My 5th gear grinds on my 07 i have 46k
my problem is i JUST got my Act heavy duty clutch and streetlight flywheel
less then 500 miles ago. will the dealer try saying its the clutch and fly even tho ive been running oem clutch and fly up until now??
Old Jan 12, 2010 | 08:06 PM
Drako's Avatar
They may...
Old Jan 12, 2010 | 08:52 PM
2slo2bfurious's Avatar
I swapped out my tranny 3 times, always that 5th or 6th gear grind. It was under warranty back then. It started to grind again after a few months from my last swap and I've learned to live with it. Works okay if i baby it. These tranny's blow.
Old May 21, 2010 | 09:38 PM
Damnn i really dont wanna buy a tranny later in my cars life will using royal purple fluid in the tranny at least Help a bit?
We put it in my friends evo 9 and it seemed to help i hope im as lucky
Old May 22, 2010 | 09:20 AM
CarlosM's Avatar
I just installed a used one in my car (06). My problem was not going into second. Never had any problems with 5th or 6th. You have extended warranty and should have no problems. Yours is the CD009.
Old May 22, 2010 | 10:42 AM
CALex's Avatar
Its the syncros in the 5th gear cluster causing your problem. Fluid at this point is not going to help the situation. Clutch can make the problem more pronounced, even assist in causing the damage, but will not fix it once the syncronizers are damaged. My 03 is doing the 5th gear grind if I shift even at a normal effort. I really have to take a "pause" to allow the gears to syncronize before enguagement. I am going to go a little different route than most others. I am going to repair mine. Being in the business myself, this is not anything that I have not done 50 times anyway. Perhaps Ill shoot some video to let you guys see what is involved.
Wish there was an easy fix for ya, friend. Just be nice to it and when the tranny comes out for a clutch replacement, you might want to consider an overhaul or swap!
Chris
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
