SFL G CLUB South Florida G35's + G37's
Hid Install
Old Mar 24, 2010 | 08:32 PM
slvrg05's Avatar
Hid Install
Hey guys I have a question about hids. I am installing a kit on Dodge Magnum with DRL. The kit wont light up cuz of this system. I just need to know how to bypass this or disable the system . I know it can be done to run a kit. Any help will be great.
randy
Old Mar 25, 2010 | 08:54 AM
GreenGoblin's Avatar
The goblin resurrection
Why would you need to bypass anything, your hid would just be running in the daytime. Your DRL and hid would be the same bulb correct?
Old Mar 25, 2010 | 09:24 AM
slvrg05's Avatar
no the DRl is the high beam too, as soon as you turn on the car the bulb in the high beam location lights up. I am installing in the correct location but . Couple people tell me its a pain in the *** to install these kits in Dodges. I am trying to prove them wrong. I was told in the Dodge forums that reversing the polarity might work. I will try this but im sceptical if this will work
Old Mar 25, 2010 | 09:39 AM
Should be pretty easy to figure out with a test light, I dont think its going to be plug an play, sounds like a cut and solder job.
Old Mar 25, 2010 | 01:50 PM
elperuano's Avatar
I got a problem with my hids on maxima... its hid highs n low but the right one always gets stuck on high so i blind everyone.. i have to hold back the switch to put it back to lows ever so lightly but if i go over a bump in the road the highs come right back on... only on the right side... cant figure it out for sheeet
Old Mar 25, 2010 | 01:58 PM
ahahah sounds like a lazy eye...
Old Mar 26, 2010 | 10:07 AM
slvrg05's Avatar
i've looked into the problem and I got different opinions, either reverse the polarity, add resistors to the oem plug or add an HID relay harness,
well lets see wut ends up to be,lol
Old Mar 26, 2010 | 11:26 AM
escobar929's Avatar
lol its cause people like you, im happy i have auto dimming on all mirrors
Old Mar 26, 2010 | 11:40 PM
elperuano's Avatar
lolz
zoop425
Mar 29, 2016 05:51 PM
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
attarday
Jul 15, 2015 04:03 PM
