SFL G CLUB South Florida G35's + G37's
Help please... Throttle body not fastening.
Old Mar 25, 2011 | 10:05 AM
NiGhT_ShIfT's Avatar
I tried installing the cooper throttle body heater that came with my motordyne plenum spacers, but while i was attempting to fasten the bolt with a torque wrench i heard a pop. I thought i broke the bold, but after taking it apart again, the bolt seems physically fine. Only the bold that i attempting to tightnen is not holding.
Any idea why this bolt is not holding? What can i do about this? There's no way that i can get away with only 3 bolts fastened correctly?
Old Mar 25, 2011 | 10:42 AM
GreenGoblin's Avatar
The goblin resurrection
First... you posted this in the classified section. Not were you would get a proper response.
More than likely you over torqued it and stripped the threads in the manifold. You will most likely have a vac leak if you use only 3 bolts.
You will have to re tap the manifold for the next size up.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
