SFL G CLUB South Florida G35's + G37's
Random dash lights
Old Sep 6, 2011 | 08:10 PM
FlopsDaCat's Avatar
Random dash lights
Hello everyone-
I posted this on the brake section, but maybe someone local can help me out.
Thank you....
https://g35driver.com/forums/brakes-...sh-lights.html
Old Sep 6, 2011 | 08:20 PM
R10T_x's Avatar
pm danny (greengoblin)
Old Sep 6, 2011 | 10:16 PM
broke_as_ajoke's Avatar
Just giving ya some to think about..
Have u check ya brake fluid levels?
when u put ya calipers back on were any of them sticking/rubbing after u drove the car?
Did u bleed the brakes? Check to see any air in the lines.. If ya pedal is soft u have air in the line. Did u check ya fuse box?
just some ideas
Old Sep 6, 2011 | 10:21 PM
gannicus's Avatar
check out your thread man see if that helps
Old Sep 7, 2011 | 12:07 AM
FlopsDaCat's Avatar
just some ideas
I did bleed the brakes. My brakes feel solid as a rock. There was problem with the dust shield when I cut it. The dust shield was bent towards the rotor so when I drove above 10mph it made a rasping sound, but I found the problem and bent the remander of the sheild away and now its perfect. About the fuses, I doubt that would be the problem but it doesnt hurt to double check.
Any help is good help, thank you.
Old Sep 7, 2011 | 12:18 PM
^ no problem bro.. i guess u gonna have to see what code it is giving you and find out what it means. Good luck bro
Old Sep 7, 2011 | 09:41 PM
FlopsDaCat's Avatar
Yeah, I am going to see if I can take it to a shop and get the codes read. Worst case thing is I will have to take my brakes apart and redo everything.
Old Sep 7, 2011 | 09:46 PM
i think auto zone or pep boys will read your codes for free.. not 100% sure
Old Sep 7, 2011 | 10:15 PM
FlopsDaCat's Avatar
^^ Yeah it doesn't hurt to stop by. Thank you.
Old Sep 8, 2011 | 10:30 AM
GreenGoblin's Avatar
The goblin resurrection
If you reset the ecu and the codes are still popping up that means the error is still there. So that rules out your maf, unless it is not clipped all the way back in. When you did the install of the akebono's did you disconnect and of the abs sensors? Also where is the fluid in the reservoir right now? Your best bet is to pull the codes to see what is causing it to go into the limp mode.
If you can get to Davie, I would be more than willing to hook it up to the computer to diagnose.
Old Sep 8, 2011 | 04:46 PM
FlopsDaCat's Avatar
Thank you for offering to help, but the funny thing is I checked the brake fluid reservoir yesterday and it was a little bit low, so I topped it off. I go to turn on my car this morning and the lights disappeared. I am releaved but confused at the same time. Hmmmmm I'm just glad it fixed its self. ...... Well anyway thank you to everyone for your help.
deschutes606
Jul 18, 2018 09:34 PM
wonderizm
Sep 24, 2015 03:09 AM
MsFitFern
Aug 9, 2015 02:58 PM
