SFL G CLUB South Florida G35's + G37's
Valve cover gasket
Old Mar 13, 2013 | 01:38 PM
GODDI507's Avatar
Valve cover gasket
What's good fam. I am getting ready to replace my valve cover gasket possibly this weekend. After reading up on a few threads it seems like a pretty str8 forward DIY job. Before I went in though, I wanted to see if any of you have done this and if so, do you have any suggestions or tips for me before I do it? I will appreciate any feed back.
Old Mar 14, 2013 | 12:33 PM
GreenGoblin's Avatar
The goblin resurrection
Yes I have done a 100, be sure to put a dap of rtv in the corners so the seal doesnt fall out when you try and put it back in.
Old Mar 14, 2013 | 04:18 PM
GODDI507's Avatar
Ok, I'll make a note of that.
I also noticed a little bit of oil in one of my spark plug units, will the replacement of the gasket resolve that issue or is there a separate seal I need to install to resolve that?
Old Mar 15, 2013 | 02:12 AM
G-off's Avatar
How much does it usually cost if you have a shop do it?
Old Mar 15, 2013 | 08:41 AM
The oil in the spark plug tube will not be fixed by that. You need to buy a new valve cover or modify it to fit different seals. I suggest just buying a new cover as the seals were not intended to be removed.
G-off send me an email to discuss. Info@slammered-inc.com
Old Mar 15, 2013 | 09:08 AM
GODDI507's Avatar
Got it. Thanx Danny. BTW, I need to hit you up about getting one of them Aluminum splash guards for my car. I'll text you bout that later tho.
Old May 23, 2013 | 07:08 PM
G_DiRTY5's Avatar
Well here's a thought
http://my350z.com/forum/engine/51287...asket-set.html
I doubt I would ever do that though because drilling holes for stuff on my car just gives me goosebumps.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
