FS: Stillen Rear Camber Adjusters and Rear Adjustable Toe Arms
Old Aug 3, 2010 | 02:05 AM
ttrank's Avatar
Grocery getter
Exclamation Stillen Rear Camber Adjusters and Rear Adjustable Toe Arms
Price includes shipping to the 48 states.
For sale, a brand new set of Stillen rear camber and toe arms.
These are Stillen part numbers: 308335 and 308365.
This kit goes for $800 plus shipping from Stillen. Here's a half price deal, $400 shipped! OBO
If you have lowered either, your rear camber is off and the best solution for the correct suspension setup is STILLEN's New Rear Camber Adjusters complete with Rod-Ends. Designed for race-precision adjustments and long service life, these rear camber adjusters are equipped with hemispherical rod-ends that allow incredibly controlled rear suspension travel & predictable response. They also improve handling and allow for even tire wear!.
STILLEN's Rear Adjustable Toe Arms are the answer to your toe angle adjustment problems. In stock form the Z's factory step up is already pushed to its limits, by adding bigger wheels and lowering your Z or G you're now prone to misalignment and premature and uneven tire wear. With these Rear Adjustable Toe Arms you are now able adjust the rear toe angle on your sports car to proper specs. When adjusted correctly you can now alleviate the issue of premature tire wear due to incorrect toe angles and improve traction stability and handling. Along with the rear toe arms, complete the combo by adding STILLEN's Rear Camber Adjusters which allows you to completely adjust your rear alignment correctly.
Old Aug 6, 2010 | 05:14 PM
ttrank's Avatar
Grocery getter
Bump
Price lowered. Also price is OBO, would like to sell ASAP.
Old Aug 6, 2010 | 10:36 PM
Epidel's Avatar
Hey tim I am really intrested in this going to pm you
Old Aug 12, 2010 | 11:01 AM
ttrank's Avatar
Grocery getter
Bump
Old Aug 17, 2010 | 11:31 PM
JZ's Avatar
JZ
G35 Coupe KY0
willing to part out? just need the camber adjusters
Old Aug 18, 2010 | 08:48 PM
ttrank's Avatar
Grocery getter
Not at this time but I will let you know if that changes.
Old Aug 19, 2010 | 02:11 PM
ttrank's Avatar
Grocery getter
Sale Pending
Old Aug 22, 2010 | 12:01 PM
ttrank's Avatar
Grocery getter
S-o-l-d
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
beevanhuynh
Jul 23, 2015 01:37 AM
