Pal-O-Mar Friday 9.12.08
Originally Posted by Calvin
you guys should come over to my place after for a beer pong tourney. yes, at 6am in the morning.
If that is the case i will school u in both of those categories.
Originally Posted by Klubbheads
am i understanding this right. Bear pong = Bear and Ping Pong?
Revised.
1. Swap to full synthetic 5w40 or 10w30
2. Trans flush
3. New Rotors/Pads
4. Install Kraftwerks
5. Install smaller pully.
6. Get tuned (K-pro? reflash?)
7. Install PLX (EGT, oil PSI, AFR, boost)
8. Install BBK (Mugen? Spoon? Brembo? APR? Stoptech? Wilwood?)
9. Install RG-R
10. Install Fire Extinguisher
11. Install Rollcage
12. Aftermarket rail + OEM seat for daily + Aftermarket seat for HPDE
13. Purchase/prep HANS/another helmet
14. Camera mount
15. Done
2. Trans flush
3. New Rotors/Pads
9. Install RG-R
14. Camera mount
15. Done
bleh..
1. Oil Change NOW!
2. Trans & Diff Fluid, NOW!
3. Install Custom BC Coils
4. Install Scott's Front Strut
5. 350EVO Soild Rear Sway + Bushings & Links
6. Install OEM Front Sway (I think its stiffer then stillen -_-) + Bushings & Links
7. Copy Rear Strut in Titanium / Steel / anything & Install
8. Suspension Tuning & Install GT-Spec Rear Braces for fun
9. Motordyne Exhaust & Straight Pipe or Fix Fast Intentions ._.
10. Install TT Kit + Every supporting mod
11. New Wheel Barrels and refinish wheels + New tires
12. Bodywork + clear bra
13. Misc ****.. Gauges, camera mount, tools, tow hitch etc..
14. Custom Front Splitter and Rear Diffuser w/wind tunnel
15. Final Drive (Longer) + LSD
16. Cage w/Custom Interior and Headunit.Audio at the sametime (Audio as in change sound system to digital)
17. Re-tune suspension + aftermarket traction control..
18. Light weight drive shaft and aftermarket rear axle
19. Engine Rebuild..
oh and about a dozen oil changes and half a dozen trans/diff in between
1. Oil Change NOW!
1. Sell AP racing BBK replace with OEM Brembo or Akebono set up and pocket 2k to 3k
2. Trade Black TE-37's for shiny wheels
3. Roll Fenders
4. Go from 245 fronts and 275 rears to 255 fronts and 295 rears
5. Pay off car about 22k.
6. Repair the rest of my credit
7. Buy a space ship!
3. Roll Fenders
1. Inflate tires to correct tire pressure - check
2. Put full tank of gas - check
3. Wash the car so it will look pretty - check
4. Don't forget to gel the hair - check
Now if I can only get off work without being so tired then I'm all set.
