SouthEast Serving AL, FL, GA, KY, NC, SC, TN
Central FL Alignments and corner balancing
Old Feb 4, 2010 | 06:32 PM
Boostwhore's Avatar
Just passing on info to anyone that may need an alignment. Performance Race Solutions formerly GBR racing has an ultra low rack and are well known for their spec alignments and corner balancing. Anyone in need of an alignment should give these guys a call
4150 ST Johns PKWY
Sanford, Fl 32771
407-878-5870
Old Feb 4, 2010 | 06:39 PM
Dubi2087's Avatar
Thanks for the heads up man, I'm getting my car ready for the track and was looking for a place with a low rack to do my alignment and corner balancing.
Thanks.
Old Feb 5, 2010 | 04:00 PM
Boostwhore's Avatar
no problem, great guys to deal with. Mike over there is well known for his spec alignments
Old Feb 5, 2010 | 04:49 PM
AboostedG's Avatar
You should post this up in the FL Section...
https://g35driver.com/forums/florida-g-club-68/
Old Feb 5, 2010 | 06:50 PM
vp-g's Avatar
what do you mean by corner balance? how is it done?
Old Feb 6, 2010 | 02:51 AM
AboostedG's Avatar
Check these out.
http://www.nsxprime.com/FAQ/Performa...nerbalance.htm
http://www.lotustalk.com/forums/f273...balance-81860/
Old Feb 6, 2010 | 07:55 AM
vp-g's Avatar
thanks what does corner balancing cost?
Old Feb 6, 2010 | 09:32 PM
Boostwhore's Avatar
Thanks, I will check the cost for you. If a couple guys wanted to get together im sure the cost would be a little less.
Corner balancing is really only noticed if you push your car to the maximum limit.
A Spec Alignment runs 109 to whatever custom specs you want. Just Aligned a new m6 on Hre 20s and Kw v3s the other day
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
