Oil consumption test
Old Nov 20, 2007 | 03:31 PM
SR20DET510's Avatar
How's it going just returned from Cerritos Infiniti after they completed my first oil consumption test.
Result= low on oil, added 1 quart
Is this normal? Well that is what the guy at the dealer told me! 1 quart per 1000 miles sounds like BS!!
I've been told on 4 seperated occasions that my car is low on oil and my oil is dark. At 1200miles (when I first bought the car, had 14 on the odometer) my check engine came on and I was low on oil.
Just before I started these test my car was extremely low on oil, oil was very dark, and I wasn't getting oil to my hydraulic lifters.
Any ideas?
Old Nov 20, 2007 | 03:52 PM
Calvin's Avatar
Overglorified Altima
This is a known issue, and quite common, with primarily the revup engines. There are a few, not many, non-revups that also had this problem.
A quick search should yield a lot of results.
Old Nov 20, 2007 | 04:04 PM
SR20DET510's Avatar
Thanks for the reply!
I am aware of the issue after reading about it here on the forums. That is why I finally had the Oil Consumption test performed at the dealer after being told so many times that my car had low oil.
Just wondering what the people that had their engine replaced, experienced at the dealer.
I was told 2-2.5 quart per 1000 miles is a problem.
I also had them order me a new head unit as my cdchanger ate my cds and wont play or eject them!
Old Nov 20, 2007 | 05:29 PM
Calvin's Avatar
1 quart per 1k miles is a problem, from what i've read on the forums.
some dealers are reluctant to replace your engine, but others will do it no problem.
unfortunately, some people have still had the oil consumption problem even after having their engines replaced.
Old Nov 22, 2007 | 06:43 PM
Startbutton99's Avatar
supposedly they fixed the problem on the latest replacement engines.
so far no problem for me. But only time will tell, as i havent even had my first oil change since i replaced my engine.
I had a long thread on this before..
Old Nov 22, 2007 | 08:17 PM
savefatkids's Avatar
they said that to my friend too. he got a new engine in his Z and now the new engine is having the same problem
Old Nov 23, 2007 | 01:32 AM
if that crap happens to me again, im done with this car..
mazdaspeed3 here i come.
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
CV35Driver
Sep 15, 2015 05:09 PM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
UT G35
Sep 3, 2015 03:58 PM
