EDO Performance Tuning Services and Installations
Hey there guys and gals!
Here at EDO Performance we not only sell parts, we perform service and installations as well! Everything from regular factory maintenance (30, 60, 90K) to installations (springs, coilovers, cat-back, turbo, supercharger, oil cooler, etc.) and tuning (TurboXS Utec, AEM, PowerFC, etc.)
A few options regarding your 30, 60, 90, and 120K services. We have the "Standard" which is identical to the dealership, uses standard synthetic oils, and another option we call the "Premium" which uses Motul Synthetic Fluids for your Motor Oil, Transmission Oil, Differential Oil, Coolant, and Power Enterprise Mag Filters (for oil changes).
30, 60, 90, and 120K Service (Standard)
- Replace Engine Oil and Filter
- Replace Engine Air Filter
- Replace In-Cabin Microfilter
- Replace Engine Coolant (Drain and Fill)
- Replace Limited-Slip Differential Oil
- Replace Manual Transmission Fluid
- Inspect Brake Lines and Cables
- Inspect Brake Fluid Level
- Inspect Brake Pads and Rotors
- Inspect Cruis Control Vacuum Hoses
- Inspect Drive Shaft Boots
- Inspect Drive Belts
- Inspect Exhaust System
- Inspect Front Suspension Ball Joints
- Inspect Fuel Lines/Connections
- Inspect Radiator Hoses
Was $450 NOW $400
30, 60, 90, and 120K Service (Premium)
- Replace Engine Oil and Filter (Motul Synthetic and Power Enterprise Mag Filter)
- Replace Engine Coolant (Drain and Fill with Motul Inugel Organic Fluid)
- Replace Limited-Slip Differential Oil (Motul Gear Oil)
- Replace Manual Transmission Fluid (Motul Gear Oil)
Was $550 NOW $500
Those of you who are interested in the "Premium" service from the dealer, that replaces belts, radiator caps, transfer case fluid (4WD/AWD), and lubrication of bearings and axle joints, that particular service will be $999! *Motul Fluids will be used as well
Tuning
Tunes via Utec, EcuTek, PowerFC, etc. will be performed on our DynaPacks. They'll start off at $450 for one or two maps (not including price of higher octane fuel).
Please feel free to PM if you have any questions or concerns.
-Danny
EDO Performance
16182 Gothard Street Unit P
Huntington Beach, CA 92647
714.602.5741
Looking forward to your service, Danny.
We SoCal members have had a lot of good service, so the bar is set high.
Where ecactly are you located? Unless I missed it, I didn't see an address.
^^ I agree Calvin, we have alot of good service, the bar is set high, gtm, street image etc. which are Outstanding shops. But their prices are also set very high!!!
EDO has very fair pricing and great customer service.
Haha Bump For Danny and Edo!! What Sup Danny!!! This 2c!!!!!
These Guys Are Installing My Procharger!!!!
And now will be doing everything for my car needs
Outstanding Shop & Great Work!!!
I Vouch For Danny And Edo
Originally Posted by G35Rider92649
Ill help a little....
They are at:
EDO Performance LLC
16182 Gothard St, Unit P
(714) 602-5741
U.S.A.
www.edoperformance.com
They are at:
EDO Performance LLC
(714) 602-5741
U.S.A.
Thnx..I google'd it earlier..It's less than 10 minutes away from my pad
Holy smokes...I posted this up...had a meeting, realized I didn't post up an address, left the meeting to try and add it, and I see posts!
QUICK STATUS!
Anyhoo, I added that info in. Total loser for forgetting.
2C, thanks for the props man!
-Danny
QUICK STATUS!
-Danny
Got my fast intention exhaust installed there today, it sounds nice, great and quick work. Thanks Danny for the service!
You So Cal G drivers should really check out this shop, especially for those who live in 714/949, i know most of you have to drive far to get work done, this is your local 1 stop shop for almost everything!
Thanks for stopping by again bro! Your goodies should be arriving soon.
-Danny
Originally Posted by jdmgee35
Welcome! I'll definitely consider you guys when the time comes for my 30k. How does your price compare to the dealer's? Just curious.
this is for all you OC folks out there....
mad props to Danny and Edwin at EDO performance...they offer very competitive price and are very nice people to work with...even got a flat screen with ps2 in the lounge
responsible professionals that will stand by their works...
i will definitely be going back there in the future...
