Wheel Gurus - Help Please
Old Jan 25, 2008 | 06:09 PM
OCG35's Avatar
Originally Posted by Wei
higher sidewall (in your case, 45 vs 40) will always be a more comfier ride,
lower sidewall will give better handling (less flex)
I think its minimal enough to not effect handling much, but enough to throw off the OEM rotation... also if I do go with the lower profile the wheel well gap will be bigger and look odd (even though I'm lowered a bit)
on another note, man, 20's tires are cheap, they're like 17 range...
too heavy though! These are the lightest wheels I can find 16.7lbs & 17.1 lbs the tires are pretty light too 28.xxlbs & 30lbs... plus they look pretty good.
Thanks for the feedback
Old Jan 25, 2008 | 07:19 PM
Jason@Riverside's Avatar
I would get some KUMHO ECSTA MX tires...
cheaper than the Toyo's... better performing IMHO... specially for CA... it doesnt rain much here (except this weekend), and they are a much grabbier tire...
Old Jan 25, 2008 | 07:30 PM
OCG35's Avatar
I have Kumho ECSTA now (on OEM 17)... cost benefit is good, but I have heard really good reviews (read and from people I know) about the Toyos... plus they are lighter than most tires... I'm gonna try the T1Rs this time. Thanks for the suggestion.
Old Jan 25, 2008 | 07:34 PM
Ecsta MX? there are a few different ECSTA's ...
Their tread is like this...
Old Jan 25, 2008 | 07:36 PM
G SEDAN's Avatar
Originally Posted by OCG35
If I run 245/45/18 it’s exactly the same as the rear sidewall weight and total diameter of 275/40/18 – which are only .4” smaller in diameter and .3” shorter sidewall…. Is there any reason not to run 245/45/18 in stead of 245/40/18?
245/45/18 is what i have on my Z track wheels.
It is the OEM Size on the 8.5 inch wheels
Old Jan 26, 2008 | 12:49 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
That's the oem size for the rear.
Mike,
You can run either the 40 series or 45 up front. 2% is within tolerance so it wont really mess anything up, i ran a 245/40 all around for the longest time. If you're not lowered too much then i'd go with the 45 series though, just to fill in some gap.
-GP-
Old Jan 26, 2008 | 07:15 AM
OCG35's Avatar
Mike,
-GP-
the more I think about it, Wei (and others) made a good point about possible flex from the taller sidewall... I was trying to match rotational speed with the 275/40 rear and 45 matches... but I should consider flex on hard cornering... and you have brought up a good point about wheel well gap (obviously I don’t want to rub)... the pic is current drop - I don't intend to go lower... the tires are 235/50/17... there's slightly less gap in front than rear, so maybe 40 profile would be better?
If I go 245/40 rotation is 2.3% faster than OEM (and quite a bit off from the 275/40 rear I'm considering)... So now I'm thinking 255/40 for the front, which is only 1/1% faster rotation than OEM (only .3" smaller diameter) - but more rolling resistance...
Damn it! I think this is one of the reasons I've waited so long to do this
Grant, what do you think about (f)255/40/18 and (r)275/40/18 ?
Here's a pic for gap reference:
Old Jan 28, 2008 | 01:00 AM
255/40 would work good as well.
-GP-
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
