changing interior lights in socal?
Originally Posted by rookie
Yes you can not drive without your gauges. Hows about you contact them and get details on turn around time. Than you can work out the details. It's about planning it out.
Without the climate control plugged in the AC goes full blast, all you need to do is pull a fuse. Pretty sure the clock display wouldn't do anything weird but show no clock and your AC control are gone anyways so no need to see the temp!
Originally Posted by Buddy Revell
Can one drive around without the Climate Control and Clock Display?
like rookie said if the controls are unplugged then the auto a/c will go to full blast but you can unplug the temp display to disable the whole cooling/heating system.
mjfenix
Aug 17, 2017 05:49 AM
