Where to install wheel spacers near the 626?
Old Mar 26, 2008 | 08:13 PM
ON's Avatar
ON
Originally Posted by O RLY
Clint says he didn't have the tools to do it, so what makes you think I would have the tools to do it? LOL
I have two screw drives and some pliers. Oh and maybe a hammer or two.
what tools do you need to put spacers on? (Obviously, i've never done it b4). But i wouldn't think you would need a whole lot of tools.
Old Mar 26, 2008 | 08:19 PM
Calvin's Avatar
Overglorified Altima
Iuno. I've never done it either. Installing the extended studs is "where it gets pricey," says the guy from WCN.
Old Mar 26, 2008 | 08:24 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
The guy from WCN is a dumba$$
You need a 21mm socket to take off the wheel. a 14mm socket or wrench to take off the caliper, a 22mm wrench or socket to take off the caliper bracket. Take the rotor off, then you soak the stock studs in WD-40 or the like, then you very gently tap the studs out of the hub with a hammer.
And for anyone that says it isnt safe to knock out the studs with a hammer because you'll mess up the hub.... you can kiss my A$$, i've done it on a 400hp EVO and he didnt have any problems with his hub thereafter, you just have to take your time and not use too much force.
-GP-
Old Mar 26, 2008 | 08:29 PM
soad's Avatar
I would do it, But I am in the 818. I have done plenty of these, including the ones on my own car.
I replace the studs with longer, stronger ones from ARP. It took me about an hour, so if I did it for you it would be like $150 more or less. After all, it has to be done right. Always use the right tool for the job.
Old Mar 26, 2008 | 08:31 PM
if you ask me, $150 is still pricey (not knocking on your workmanship), i wouldnt pay more than $80 for each axle to get this done if i didnt know how to do it myself. If i still worked at the shop then i would have done it for Cal for $40 (yes that would be selling myself and my skills at working on cars short, but i'd rather hook up a fellow G driver than rip them off)
-GP-
Old Mar 26, 2008 | 08:49 PM
istan's Avatar
WCN is not known for the good pricing on misc labor. They charge by the book.
Just come to Vegas
Old Mar 26, 2008 | 10:18 PM
Calvin's Avatar
-GP-
Booo. Come back to SD. And bring your girl here, too. Fvck LA.
Old Mar 26, 2008 | 10:19 PM
and leave all the cars i get to shoot up here??? hell no!
-GP-
Old Mar 27, 2008 | 12:25 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
i'll do it for free. i'm never done it before, but that goes the same for when i installed my exhaust, plenum spacer, bbk, sway bars, etc, etc.
i have replaced the wheel studs on my '94 corolla
Old Mar 27, 2008 | 12:37 AM
soad's Avatar
-GP-
Thats cool and all, but doesn't $80 per Axle make it $160 ? just asking. Yeah i am not trying to Rip any one off or anything, but that the best that i could do for you on that would be $100.
I would just do it my self, find a buddy near by and make it Saturday morning project.
Old Mar 27, 2008 | 12:38 AM
rookie's Avatar
It's not hard to do, just need to fully seat the studs. A pry bar to counter the hub when seating the studs is a must or someone will be holding the brake pedal.
Old Mar 27, 2008 | 12:43 AM
That would make it $160 front and rear. He only needs the fronts done.
-GP-
Old Mar 27, 2008 | 01:10 AM
Johnmikins's Avatar
Dude if you can change breaks you can do this...dont waste your money. If you cant change breaks your gonna get screwed by some shop so open up the wallet! I did mine, but hell im a little daring! Hammer and socket wrench baby!
Old Mar 27, 2008 | 01:16 AM
LightsOut's Avatar
SIETESG
one of the threads hear Alignment plug the alignment place in temple city they charge 70 per axle. i know cause i asked them when i was there. i wanted to install my spacers there.
Old Mar 27, 2008 | 01:23 AM
  #30
ON's Avatar
ON
Calvin doesn't know how to change brakes. hahaha.
Calvin,
if you want to swing by my place, we can attempt it. From the way Grant explained it, it doesn't seem so hard.
I've changed brakes on a few cars before, so I don't think putting on a spacer will be a problem.
