Help {brakes}
Old Apr 23, 2008 | 10:55 PM
red35nlwd's Avatar
Help {brakes}
so i changed my front brake pad on my G.. me and my friend werent sure how to do it so we did it the hard way we took of the four screws with the alan wrench and didnt realized the brake fluid would drain..
so once putting the new brake pads on i had to bleed the brakes, when finish i wasnt satisfied becuase when i brake the first pump goes almost all the way and the following r good...
Does n e one knows how to bleed the brake systen on a 2003 G coupe w/Brembos?
Old Apr 23, 2008 | 11:30 PM
PrecisionZ's Avatar
First fill the master cylinder and have someone hold down the brake pedal.
Open the bleeder screw on top for about one second and close bleeder. Pump the pedal once and bleed again. Do this until the fluid comes out clear (no air bubbles). Now do the same on the other caliper. Call me at work tomorrow if you need more help.
Ed
Precision Z
818-716-6744
Old Apr 24, 2008 | 12:07 AM
red35nlwd's Avatar
thanx for the instruction but i tried and no good results..
R u local,,,
call me u can
raul
310-946-8115
im on way to work...
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
