So Cal OC fender rolling!
hi guys, alot of my clients a g owners and have told me to post on your forum as well to let you all know.
anywho, ive been on my350z since Oct 2002 and have a great reputation on my350z. check out my thread:
http://www.my350z.com/forum/showthread.php?t=276786
i know many of you may need/do need this done to your cars; especially if you run agressive offsets and are lowered.
i can offer you the service of rolling fenders right here in the middle of OC. dont need to go places that will charge you $75 per fender.i've been to shoreline motoring, in huntington beach, and they charge about $150 just for the rear at a mild roll.
my fender rolling procedure:
Pre:
1. Raise Vehicle using low profile jack and support using 3ton jackstands
2. Remove wheel/tire using only a 1/2in wrench- no impact wrench to scratch your wheels.
3. Bolt on Fender roller
Roll:
1. Clean the area to be rolled- this way you can avoid pits in the paint
2. HEAT the area to be rolled- This helps the paint to flex as much as it can
3. Roll- Depening on how much you need to roll, i can do a mild or a super agressive roll.
The complete procedure usually take about 1hr to complete.
***I CANNOT guarentee your paint will not cack. I take all the necessary precautions though of cleaning and heating the paint to avoid this. It just so happens that we are modifying a CURED painted panel. i will try my best to avoid this and it usually isnt much of a problem on newer cars.*****
i can offer you this service per pair of fenders. right now im only offering the rear fenders rolled as i have not had any experence rolling the fronts yet. im located in newport beach right off the 73 frwy.
pm me if any of you guys wanna set any appointments up.
*as deviljon and i have found, rolling the fronts is not necessary or even possible. they are already pre-rolled from the factory and require no more rolling.
Pre:
Roll:
Originally Posted by soad
Yo Daytona. I have referred a couple of members to you that had hit me up in the past and that stay in the OC.
Just a quick heads up
ive done the same on the z board for the members that are in LA
Just got my fenders rolled by daytona350z and he did a excellent job! Takes care of the vehicle and informs of any possible damage that could take place due to any existing scratches or body work that may have been previously done to fenders. Very affordable, fast and well worth it. Highly recommended for anyone needing a fender roll!
