Check engine light is on? what do i do?HELLLLPPPPP!
Old May 4, 2008 | 02:39 PM
InfinitSkyline's Avatar
check engine light is on? what do i do?HELLLLPPPPP! whats causing this? any shop that can help?
Old May 4, 2008 | 02:44 PM
Calvin's Avatar
Overglorified Altima
It's hard to tell you what's causing it without more information. An new mods recently?
Take it to Autozone and see what code you get.
Old May 4, 2008 | 02:49 PM
Originally Posted by aHero4Eternity
It's hard to tell you what's causing it without more information. Any new mods recently?
No mods....i dont know but my mechanic is coming over tomorrow...hopefully nothing big.
Old May 4, 2008 | 02:52 PM
rookie's Avatar
+1, service manual lists all codes.
Old May 4, 2008 | 03:05 PM
G37Rider92649's Avatar
If you're around 714 I can help you, I got a obdII scanner that can check/scan your ecu and get the codes.
Old May 4, 2008 | 04:00 PM
ummmnn....i work in la habra....how far are you from beach and imperial?
Old May 4, 2008 | 04:05 PM
Nismo G's Avatar
If it is just the check engine light it is nothing serious.
-Sean
Old May 4, 2008 | 04:08 PM
-Sean
Im worried but thanks for positive feedback...
Old May 4, 2008 | 04:10 PM
Nismo G's Avatar
When things like vdc/slip/abs/airbag and everything else start turning on...that is when something is really wrong.
Check engine...usually something small.
-Sean
Old May 4, 2008 | 05:03 PM
I'm located on the other side of Beach, around Edinger area haha, but I can help ya find the problem with my scanner if you want, takes 5 minutes.
Old May 4, 2008 | 06:05 PM
O HELLA JDM's Avatar
if the light is on....maybe just unplug ur black battery wire.... overnigth about 12 hours and it should be gone...if not then you have to bring it in
Old May 4, 2008 | 06:11 PM
EricIsKlumzyee's Avatar
Dont reset the ECU.. it doesnt do anything but clear the cold along with everything else.. radio stations, drivers adaptation, fuel maps etc..
Bring to autozone they'll pull the code for free... or take it to SEARs and tip a kid $5-$10 and they'll pull the code as well =P.. once you get the code google it and see what you get or post it up here.. then we'll help you out..
Check basics first.. hows your idle? good? not rough? etc..
Check engine light usually has to do with emissions..
Old May 4, 2008 | 07:04 PM
Yea my mechanic will check it tomorrow....im prety busy tonight....guess what eric? Im pickin up an 94 EG tonight hahahaha.....and its white....damn....watsup with me and white cars....first i had white celica, then an 86 white corolla, then a 2001 corolla type S, Current G IP...then EG for dailing driving?...oh my...
Old May 4, 2008 | 07:06 PM
LOL.. EG x.x lol big difference from the G man..
let me know if u guys cant figure it out. i'm pretty good with diag n have tools at home..
Old May 4, 2008 | 07:13 PM
express705's Avatar
its going to blow up
