Tires bald after 7K miles. Help!!
Old Aug 20, 2008 | 07:06 PM
Ali Shah's Avatar
Guys I have a question. I have after market wheels, 20x9.5 and 20x10.5. The tires are 245/35/20 and stretched 275/30/20 falken 452s. After only about 7K miles my rear tires are EVENLY balding. The wear bars are showing.
Now if it was just the inside wearing then i would just get a camber kit. But this is worse cause i dont know what the problem is. lol BTW I believe i have about -2 degrees of camber. I dont remember the exact camber cause my print out is at home but its not more than -2 degrees.
I dont launch hard but i do take corners hard. Any ideas why its balding so fast? How long do your 20" tires last? Thanks!!
(i put this up in the national forum under tires so if i am not allowed to put the same topic in two categories, i apologize)
Old Aug 20, 2008 | 08:02 PM
nissandriver's Avatar
stop doing burnouts
Old Aug 20, 2008 | 08:50 PM
Skaterbasist's Avatar
Retired SuperMod
7K mikes???
Old Aug 20, 2008 | 09:11 PM
CandlestickPark's Avatar
ill Sedan
Not sure why they would go bald so quickly. I'm running 245/40/19 FK452s and I got 15K out of my rears running -2~-2.5 camber in the rear.
Old Aug 20, 2008 | 10:39 PM
mIKE's Avatar
You need to slow down
Old Aug 20, 2008 | 10:44 PM
gEE805's Avatar
what are the tires spec?they soft tires?? usually tires that are softer well have better performance BUT wear real fast
Old Aug 20, 2008 | 11:06 PM
B L U E S L A T E's Avatar
Honda Accord
I got 10k miles out of my Falken 452s... with -1.6 camber in the rear, and this is with about 5 canyon runs + 3 tracking (drag).
I've also done numerous burn-outs. lol
Old Aug 21, 2008 | 12:16 AM
Johnmikins's Avatar
Sounds like a case of bootleg tires...you get um from China?
Old Aug 21, 2008 | 12:26 PM
Ali Shah's Avatar
The only reason i can think of is that i drive to fast around turns/corners but shouldnt make it go bald so fast. Its not i am sliding through corners. do you think the tire being stretched has anything to do with it?
Old Aug 21, 2008 | 12:31 PM
Ali Shah's Avatar
Quick question, are you flying around corners in the canyon runs up to the point before you start sliding? the reason i ask is cause that is my normal driving habit and i was wondering if that could cause balding. i thought only sliding/drifting would cause balding that fast.
Old Aug 21, 2008 | 12:36 PM
Honda Accord
Driving to the fullest in the canyons.
Old Aug 21, 2008 | 12:38 PM
SFLG35's Avatar
FGC President
sounds like you have toe problems not camber problems
Old Aug 21, 2008 | 12:43 PM
mIKE's Avatar
I have about 14k on my RE070s. Local members can attest to the fact that I will push the tires to the limit with 20+ canyon runs and 3 track days on the current set. I'm at 3/32" on the front and 2/32" on the rear.
Funny part is these tires average about 8-10k with non HPD... I go through my rears slower than the norm, but I go through my fronts faster than the norm.
I'm currently running -0.3 front, -1.3 rear.
It's also a s2k.
Old Aug 21, 2008 | 01:11 PM
Ali Shah's Avatar
I wish that was it so i can explain the problem. lol toe is 0.13 left rear and 0.10 right rear (within specs). camber is -2.3 left rear and -2.0 right rear so you would think the inside would wear way faster than the outside but they are wearing almost evenly.
off topic but does anyone no why the hell i would have a -1.0 SAI for the front left and +4.0 SAI for the front right. also -2.9 included angle for the front left and +2.5 included angle for the front right.
Old Aug 21, 2008 | 01:12 PM
Ali Shah's Avatar
It's also a s2k.
ok so basically i just have some weird bad luck lol maybe the 452s suck in tread life.
