Megan A-Arms
Old Sep 28, 2008 | 06:57 PM
g30wh4t's Avatar
Megan A-Arms
Need some advice from my so cal peeps.
I just pulled my tires. I just burned through my ps2's from putting 350 s-techs on.
I found a set of megan a arms for about $200 from a friend. My question is, will this fix my camber enough to get rid of my inner tire wear.
here is the link to the product
http://www.hopupracing.com/merani35ing3.html
Thanks!
Old Sep 28, 2008 | 07:20 PM
Dranom's Avatar
Thanks!
so you dont have front camber arms when you installed your springs?
i think front camber arms helps a lot to even out tire wear.
About your link it doesnt say how much adjustment you can do w/ those arms. get some SPL or 350evo's if you have extra $$$. ive heard those arms does a good job. i have SPLs and i got my alignment to stock
Old Sep 28, 2008 | 08:27 PM
Calvin's Avatar
Overglorified Altima
These arms will not correct negative camber.
Old Sep 28, 2008 | 08:46 PM
g30wh4t's Avatar
damn, ok thanks cal!
Old Sep 28, 2008 | 09:02 PM
gary c's Avatar
G35 Tire eater....?
In the next few months I'll be installing the SPL Pro upper a-arms prior to my
going back to Michelin's. The Bridgestones won't wear out by then but I
really dislike these tires, terrible noise at slow speed and you have to drive
on them for six blocks before they get round....strange! Adjustable a-arms
and new tires should get rid of my noise at slow speed....with luck!
Gary
Old Sep 28, 2008 | 10:51 PM
G37Rider92649's Avatar
I'm using the SPC Front & Rear Camber kit and it works for me, but personally I prefer the 350EVO front cambers
Old Sep 29, 2008 | 02:11 AM
g30wh4t's Avatar
yeah 350 evo's are nice but expensive. I am going to put back my stock suspension and do the spring mount mod to lower the back a little bit. The front was not bad at all but the rear had way too much room. To me its not worth the $500 to $600 worth of camber, plus alignment and adjustment + 2 new tires to have a little nicer look. I am picking up 350evo sways thats about it. BBK is gone on thursday. The car is nice already.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
DRG35R
Sep 16, 2015 05:33 AM
Moskvitch
Sep 14, 2015 10:15 AM
kevintandmd
Sep 3, 2015 06:41 PM
nickmcc123
Aug 20, 2015 03:10 PM
