h&R wheel spacer installation
Originally Posted by imjackiechan
the only real and fRRuckin annoyin problem im having is the rear brake caliper nuts and caliper brace nuts... gahH ... >:[
i havent tried the fronts yet though
Originally Posted by Nickk6
lift the car high enough up so you can stand under neath it with a breaker bar, break the bolts holding the calipers. You only need to move it like an inch or two and then you can just get back at it with a regular ratchet. After that take the caliper off, then rotor.
+1
nooo but in the back brakes theres a HUGe bar thats holding the axle
and its blocking the lower bolt from comingout at all
so the midas guys told me taht if i want to takethe caliper out then i have to take that bar off.
lol
