EDO Performance Regular Maintenance Service
Old Oct 24, 2008 | 06:23 PM
EdoPerformance's Avatar
EDO Performance Nissan & Infiniti Factory Regular Services
Oil Change & Filter from $25
15,000 & 45,000 Miles Service $78
Replace engine & Oil Filter
Replace in-cabin filter
Rotate tires
Inspect:
- Automatic transmission fluid
- Brake lines & cables
- Brake calipers, pads, rotors
- Brake lights & cruise control switches
- Differential oil
- Drive shaft boot
- Manual transmission oi
- Propeller shaft
- Transfer case oil
30,000 and 60,000 Miles Service $280
Replace engine & oil filter
Replace climate controlled seat filter
Replace Engine air filter
Replace in-cabin micro-filter
Rotate Tires
Inspect:
- Axle & suspension parts
- Brake calipers, pads & rotors
- Brake light & cruise controll switches
- DIfferential oil
- Drive shaft boots
- Exhaust system
- Front suspension ball joints
- Fuel lines/ connections
- Fuel tank vapor hoses
- Propeller shaft
- Steering gear & linkage
- Manual Transmission oil
- Transfer case oil
* Prices may vary according to year and model of the vehicle
Old Oct 24, 2008 | 06:43 PM
EDO Perfomance New Service Team !!
EDO Performance has a new service team.
The new team is lead by service manager Robert Krencik, ASE certified with 21-year service experience including with Mercedes Benz. Working alongside Robert, is Jacky Ching who is a 26-year automotive veteran with various renowned automotive brands.
If you have any service inquiries, please feel free to email Robert at robert@edoperformance.com
We look forward to serving you in the near future!
Old Oct 24, 2008 | 06:51 PM
EDO Performance Nissan & Infiniti Factory Maintenance Service
90,000 Miles Service $398
Replace oil & filter
Replace engine air filter
Replace engine coolant
Rotate Tires
Inspect:
- DIfferential oil
- Drive shaft boots
- Transfer case oil
- Propeller shaft
- Fuel lines/ conections
- Exhaust system
105,000 Miles and 120,000 Miles factory services are also available. Please Contact service manager, Robert Krencik, at robert@edoperformance.com
Old Oct 24, 2008 | 06:52 PM
Calvin's Avatar
Overglorified Altima
$25 for synthetic oil change? what oil do you guys use?
Old Oct 24, 2008 | 07:23 PM
$25 for regular.
For Synthetic oil we use Motul for $65.
Old Oct 24, 2008 | 09:40 PM
EDO Performance Service Hours
Mon - Fri : 8.30AM to 5PM
Sat : 8.30AM to 5PM (By Appointment)
Old Oct 24, 2008 | 09:41 PM
LightsOut's Avatar
SIETESG
$65!... W.C nissan is cheaper and other local mechanic shops, and walmart is cheaper.
sorry bad day im stuck at work..
Old Oct 27, 2008 | 09:55 PM
dspiel's Avatar
I just got my oiled changed at Performance Nissan with Motul oil for $60, thats their regular price. They usually have a special going on for $50. Oh and they will wash your car for free.
Old Oct 27, 2008 | 10:52 PM
G SEDAN's Avatar
What does it mean to inspect? will you guys charge extra if it's found to need new tranny oil and rear differential fluids? drain n fill or a full flush?
I would recommend you guys actually offer the factory recommended service schedules on your package deals
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
carsmacked71
Sep 18, 2015 04:13 AM
DRG35R
Sep 16, 2015 05:33 AM
