jdm v35 sedan LED mirror cover install
#31
mirrors are working now check out my other thread for more pictures and videos
https://g35driver.com/forums/media-s...s-working.html
#32
quick question for those that installed this item. My local Nissan dealer said that they can order the part from Japan with no issues but:
1. There is no warranty as this is a Japan Market only item.
2. They cannot guarantee installation until they have the item physically in hand. This is because they don't know if any wires or harnesses have to be added so that the signals on mirrors can function.
Can anyone please advise if the installation is simple plug and play? Do they need to modify the wiring?
Thank you!
Thank you!
#33
Thank you!
Thank you!
i am not sure if you have seen my other thread check it out i have some picture of the instructions on there
i installed this myself and everything was plug and play for me i did not run into any problems
i did not have to modify any of the factory harness nissan includes everything in this kit to install them right
instructions maybe a lil hard to understand at 1st cause they are in japanese and diagram pictures are of a right hand drive v35 so if it tells you to do somthing to the right side then for USA infiniti it would be left side
what ever you do just make sure who ever installs these for you does it right with all the hardware in the kit one reason i installed these myself was cause i did not trust some of these people they wanted to half *** the work and not want to install it the right way and still charge me a arm and a leg some people wanted just to tap into fender well and just wire it up to the blinker harness
so one day i just study the instructions really hard and got it done took me 2 days with the help of a friend but got it done and well worth it
so if me and my friend can do it in my backyard with japanese instructions iam really sure the dealer should have no problems doing the install for you
#35
joedaddy1
07-28-2015 02:58 PM
