g35 oil change
Old Nov 3, 2010 | 02:40 PM
Swivel's Avatar
Moderator
Originally Posted by chrismtb
Of course, you could take the splash guard off if you'd prefer removing and replacing the 30 screws rather than dealing with the oil filter awkwardness.
Taking the time to do it that way is MUCH easier and cleaner. And I don't think there are more than about a dozen. Little speed tip: crack each one loose with a 10mm socket or wrench, then throw a Phillips head or 10mm socket bit in your cordless drill, throw it in reverse and spin those babies out. If you're really slow, it'll take about 2 minutes. When reinstalling, do the reverse: start them all, spin 'em all in until just snug, then give each one a little torque with the 10mm.
Just finished doing mine.
Old Nov 3, 2010 | 03:34 PM
LightsOut's Avatar
SIETESG
I just go to Temple City Auto Repair.
take my own oil and for 10.00 Henry does everything. Also checks tire pressure and fluids.
he also does Amsoil motor oil changes for cheap under 60 I think, And Diff oil change with Amsoil for 60.00 or so.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
ghost_g35
Aug 7, 2015 10:31 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
newbdriver01
Jul 15, 2015 06:10 PM
