g35 high rpm shifting
Old Jun 27, 2010 | 04:13 PM
rahmani15's Avatar
hey sorry if this was posted before but i can't find it >.< anyways when i drive my car fast in high rpms and shift fast and dump the clutch i hear a loud BANG sounds like its coming from the rear dif almost im not to sure, when i shift slow its fine, my friend has a 350z and he drove my car the same way and still got that back so its not how im shifting or letting the clutch out he drove it the same way i don't know what this could be i don't do it often i just drive it normally and i can't find anything like this one the internet, any ideas?
Old Jun 28, 2010 | 01:15 AM
mIKE's Avatar
Sounds like a shock load to the diff.
Miles on the car? Maintenance? Mods?
Don't dump the clutch if you want your drivetrain to last.
Old Jun 28, 2010 | 01:47 AM
Hotdawwgman's Avatar
^ exactly what Mike said, When was the last time the diff fluid was changed too? Might have a small leak to and never know!
Old Jun 28, 2010 | 01:25 PM
rahmani15's Avatar
the dif fluid was changed about 10k miles ago mods include berk test pipes and berk ztube but it did this before the mods it has 70 miles on, clutch has about 15k miles on it all maintanence has been up to date
Old Jun 28, 2010 | 01:30 PM
jlo0109's Avatar
Dont dump your clutch.. even you're at high RPM. Your RPM is high enough to shift even without clutching.
Old Jun 28, 2010 | 05:19 PM
mIKE's Avatar
Maybe he's trying to chirp his tires... :shrug:
Old Jun 28, 2010 | 06:01 PM
Jairen's Avatar
Check your rear differential bushings. Check for black streaks on the differential cover. Let's try that first or quit dumping the clutch at high RPM's. There's no reason to do it unless your trying to do a burnout or donut's...on the street.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Tonka211
Jul 25, 2015 03:22 AM
laksjd84
Jul 24, 2015 05:12 PM
006
Intake & Exhaust
Jul 19, 2015 04:30 PM
Jadenkid22
Jul 14, 2015 12:33 AM
