P0420 - Anyone get this code before?
Old Oct 27, 2010 | 04:49 PM
KingCobra's Avatar
P0420, P0430 Catalyst Efficiency
Code P0420 indicates that the exhaust gas exiting the catalytic converter is too similar to the exhaust gas entering the converter. A faulty or overloaded converter due to an unbalanced air/fuel mixture can cause this condition.
Anyone have this problem with their G before? What could it be?
My G has 90k miles on it, could it be the cats?
It says it may also be 02 sensors, or a few different other issues, but mainly it seems to be either the Cats or the sensors...
Thanks!
Old Oct 27, 2010 | 06:12 PM
VEEG35.0's Avatar
do u have any smoking or power loss
Old Oct 27, 2010 | 06:17 PM
KingCobra's Avatar
nope, also when I use the scanner it actually says the o2 sensors are fine....
Old Oct 27, 2010 | 06:19 PM
VEEG35.0's Avatar
well ur getting hfc right maybe that will fix it
Old Oct 27, 2010 | 06:56 PM
KingCobra's Avatar
ya but not for like a couple months
Old Oct 27, 2010 | 07:13 PM
VEEG35.0's Avatar
just google the code that brings up a lot stuff
Old Oct 27, 2010 | 08:14 PM
KingCobra's Avatar
ya ive been reading up a lot about it just nothing really clear is out there, even on here theres only a few threads talking about it and not really informative
hey do you know how long stock cats should last for?
Old Oct 27, 2010 | 08:23 PM
VEEG35.0's Avatar
it depends on how u drive and the mods u have, how hard u drive is a big part too
my guess is they should go for at least a 100,000 if not more
Old Oct 27, 2010 | 10:31 PM
VolkZ's Avatar
if the front and rear sensors are reading the same, the cat is bad.
Old Oct 28, 2010 | 05:12 PM
KingCobra's Avatar
Dunno how to check the readings for front and rear sensors and Im guessing i dont have the tools to...
BUT, my scanner does check the sensors and it says the o2 sensors pass fine with no issues
Old Oct 30, 2010 | 04:44 PM
VolkZ's Avatar
thats the one, o2sensor 1 and o2sensor 2. compare the voltage high's and voltage lows
Old Nov 3, 2010 | 05:58 PM
KingCobra's Avatar
the scanner doesnt give me the readings for the o2 sensors, just weather it passes or fails
Old Nov 11, 2010 | 12:34 AM
jebus2006G35's Avatar
i got the same thing today bro. same code. i have 300 cell HFC. havent had them for more than a year. car has 40k. i dont know what 2 do either. sucks
Old Nov 11, 2010 | 01:30 PM
found this bro. im gana try it todayhttp://www.civicforums.com/forums/7-honda-civic-diys-civic-tech-chat/329421-diy-o2-sensor-bypass-spark-plug-non-fouler-trick-installation-w-pics.html
Old Nov 11, 2010 | 08:22 PM
KingCobra's Avatar
^ let me know if that works....i just got Megan TPs and got the check engine light...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
