Throttle Body Cleaned... failed! Help please!
Old Feb 8, 2011 | 04:13 PM
rkim210's Avatar
I cleaned my throttle bodies, but I forgot to disconnect my neg. battery terminal. After I put everything back together, I started the car up, the idle started high, at about 2k.
After warming up, the engine idle surges from 2k, drops down to about 900, then back to 2k, and then to 900 again. I drove it for a bit, then the SES light came on.
I checked around the forums for an answer, and tried the idle air volume learning, just with failure and disappointment. I must not be doing something right.
Is there anyone in So. Cal (I live in LA, work near Rancho Cucamonga) who has performed the Idle air learning procedure and probably a ses light reset?
Old Feb 8, 2011 | 07:02 PM
OCG35's Avatar
follow the instructions below precisely and use a stop watch, timed precisely... might take a couple tries, but it will work.
Old Feb 8, 2011 | 07:04 PM
OCG35's Avatar
just realized you mentioned throttle bodies... do you have an HR?... not sure if the attached above works for HR...
Old Feb 8, 2011 | 07:06 PM
juan350gt's Avatar
I had that issue before, but its nothing to worry about,hope someone here can help.Sean who lives in Corona might be able to help.. I tried the manual you have there and Failed as well probably cause i am not very accurate with it either.
Old Feb 8, 2011 | 07:09 PM
OCG35's Avatar
timing is critical... I've cleaned my TB many times and only had a problem the first time (that's when I realized disconnect bat then actuator)... the first time I had a problem I had to do the relearn procedure twice, second time was timed precise and worked.
Most people that report it not working end up getting it to take when they keep trying... others give up and buy new TB.
If you keep trying and time it precise, it will work.
Old Feb 8, 2011 | 07:24 PM
SxExCx's Avatar
You should also reset the ECU before the attached proceedure listed above. If you need help doing it, you can bring the car to me in Corona (off the 15/Limonite)
Old Feb 8, 2011 | 07:38 PM
Hotdawwgman's Avatar
hmm. I need to clean my TB
Old Feb 8, 2011 | 07:44 PM
rkim210's Avatar
Do you have time on Thursday or Friday? I'm soooooo close to you... I work at the tire shop in the Pick-a-part off Milliken.
Please help!!!!!
Old Feb 8, 2011 | 07:50 PM
rkim210's Avatar
I have a 07 G35 Sedan
Old Feb 8, 2011 | 08:35 PM
SxExCx's Avatar
Please help!!!!!
Thursday after 8pm or Friday after 5pm. PM me if you want to swing by.
Old Feb 8, 2011 | 09:32 PM
crashnburn's Avatar
i did this and took to dealer 10 times to try to fix.. they fixed it for bout 10 mins at max.. ended up buying another tb and never had a problem again
Old Feb 8, 2011 | 10:15 PM
iloveG's Avatar
idoits..
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
