possible valve adj ??
Old Nov 3, 2011 | 02:25 AM
g35kid18's Avatar
whats going on guys need ur help here. Im having this horrible ticking noise coming from my car and white smoke coming from the exhaust when i gas it.. im assuming its in need of a valve adjustment. i went to a local shop in whittier Mikes Z shop and they told me i needed thicker oil. i knew that wasnt the proper solution because it was just going to masking the noise. So what place should i take my car where they know what they are talking about.
Thanks in advance
Old Nov 3, 2011 | 10:09 AM
slim17265's Avatar
I second the thicker oil. try 15w40 Shell
Old Nov 3, 2011 | 10:18 AM
joedaddy1's Avatar
I would try M1 0w-40 or GC 0w-30..
they are both thicker than your average...
Old Nov 3, 2011 | 03:20 PM
g35kid18's Avatar
I was actually really hoping that it was just oil because I had them change it to 20-50 but still had the ticking sound.. any other suggestions would really appreciate it
P.s. the motor only has 86k miles on it
Old Nov 3, 2011 | 10:01 PM
joedaddy1's Avatar
is your car 05/06 6MT?
if so.. you should read the oil consumption TSB.
Old Nov 4, 2011 | 01:46 AM
g35kid18's Avatar
Might sound like a noob question n thanks for the input but no its a 03 mt what is tsb
Old Nov 4, 2011 | 07:34 PM
RacerX35's Avatar
TSB = Technical Service Bulletin.
Try the thicker oil. I don't think you'll find places that would recommend a valve adjustment.
I've never heard of doing a valve adjustment on any of the newer cars with variable valve timing and all that.
Later,
Ray
Old Nov 4, 2011 | 07:51 PM
threatcon07's Avatar
Yeah that definitely isn't the proper solution. If you are closer to San Fernando Valley, head to Specialty Z in Chatsworth. If you are closer to Orange County, go to Corner 3 Garage in Lake Forest.
I second racer x...I used to get valve adjustments on my Integra, but never on my G in the last 90,000 miles.
Thanks in advance
Old Nov 4, 2011 | 08:36 PM
g35kid18's Avatar
i did already try the thicker oil but that was no luck... ill hit up corner 3 see if they can figure it out thanks a lot guys
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
TNRocker
Sep 21, 2015 08:36 AM
