Tps Light?!
Old Apr 14, 2005 | 12:35 PM
cRai6ory's Avatar
my TPS light comes on almost every time i drive the car for 40+ miles straight. Happened ever since i got my rims. Whats weird is i dont even have the sensors on the rims. Anyone know wth is goin on?
Old Apr 14, 2005 | 01:42 PM
THX723's Avatar
G Kreuzer
Romi,
I'm so glad your homies were able to offer you nothing but air (no pun intended).
Here's the real deal. Your tires may look 'fine' to you, but I'm 99% sure, one of them is near the 28psi mark (during the colder night), which is the cut-off point for the TPS alarm to chirp. Check all four w. a proper guage then fill them all back up to 34psi and your set. If you have access to Nitrogen air like Dizz said ... even better, but don't sweat over it.
Lates,
Old Apr 14, 2005 | 01:45 PM
THX723's Avatar
G Kreuzer
cRai6ory,
You've got a whole another issue. Your TPS's aping on you because you haven't got any TPS sensors on at all (w. your new kicks). The system does a periodic check of the sensors and when it doesn't find it ... the dash light goes off. You'll have noticed it didn't 'screamed' at you for 10 seconds like it did to G35Chick. It just '' at ya! So, unless you remount those sensors (assuming it's compatible w. your new wheels), that'll be a periodic affair fo ya!
Cheers,
Old Apr 14, 2005 | 02:31 PM
Dizz's Avatar
Clint, for some reason, I can't imagine you in a coupe. The sedan is so fitting for you.
Btw, who got cut from Idol?
Old Apr 14, 2005 | 04:02 PM
THX723's Avatar
G Kreuzer
If the 4D hadn't come in 6mt ... I'd be sport'n the 2D as well.
Nadia gots the boot! Grace's other boy friend lives!
Old Apr 14, 2005 | 04:27 PM
GReddySetGO's Avatar
So next time its cold and that light comes on, do a few burn outs to heat them up.
Old Apr 14, 2005 | 04:41 PM
DOHCtor_Dan's Avatar
Originally Posted by Dizz
Yeah Hiromi, you may want to try nitrogen in your tires
i don't know how readily u can get a hold of nitrogen to keep around you all the time. but i know that donny constantly emits methane gas; sometimes on and off command.
Old Apr 14, 2005 | 05:08 PM
Dizz's Avatar
Pfffft!!!
Clint, Nadia was getting weak and I still want to fight Constantine.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
