Shell Spirax S 75-90 Is Back!!
Old Oct 6, 2005 | 06:06 PM
EricIsKlumzyee's Avatar
I did the tranny and diff a few weeks ago.. def a difference.. alot smoother when its cold and even better when it gets hot
Old Oct 6, 2005 | 11:17 PM
GRider35c's Avatar
im getting my car back 2mrw!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 22, 2005 | 08:54 PM
chiapet15's Avatar
I have an 05 6MT coupe with almost 4K miles on it now. Changed out the stock Nissan fluid to Spirax S, and boy was there a difference. The shifter is now buttery smooth. The car is definitely more efficient at putting power on the ground now. I can now easily run the engine at 1200 RPM in 6th gear at 35mph in my conservative driving mode.
Old Oct 23, 2005 | 05:02 PM
GRider35c's Avatar
do the diff fluid also... get rid of the metal shavings...
Old Nov 12, 2005 | 10:52 AM
Gidyup's Avatar
Can Shell Spirax S be used in Limited Slip Differentials like ours? I have read the Shell product sheet for this oil and nowhere does it state that its for LSD's. There is a Spirax LS, which I think is not synthetic like the Spirax S.
Do we have to add a LSD additive if we use Sprirax S?
Here's the link for the Sprirax S data sheet:
http://www.shell-lubricants.com/prod...df/SpiraxS.pdf
and Link for Spirax LS data sheet:
http://www.shell-lubricants.com/prod...PIRAX%20LS.PDF
I'm in the NY/NJ area and I have bought 6 quarts of the Spirax S oil but want to make sure it's the right one for our G35 coupes.
I bought it from the location below at $6.00 a quart.
Bolkema Fuel Co., Inc.
75 Mollie Ct.
Mahwah , NJ 07430
Phone: 201-891-1000
Or you can find a local dealer in your area with this link:
http://www.shell-lubricants.com/distributors.php
apintojr
Jul 23, 2015 10:52 AM
